Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator dogs keep wearing out
I have replaced the dogs 3 times and they continue to wear down
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Ur over loading the washer to often
Posted on Jan 04, 2014
vest6
  • 196 Answers
SOURCE: Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Posted on Jan 02, 2008
  • 958 Answers
SOURCE: agitator dogs
it is really tricky. i hope this would help you do it.
http://www.davesrepair.com/DIYhelp/DIY285770pf.htm
tnx 4 using fixya,
drcool
Posted on Oct 22, 2008
To disassemble, you need to destroy the tabs that are holding the translucent thing to the four post on top of the bottom part. This of course means that the translucent thing needs to be replaced too. I hammered the screwdriver into the tabs until they gave way. The rest of teh parts come out undamaged.
(if you have snips with really long handles, that would be a better tool).
Posted on Dec 12, 2008
aborcass
  • 2651 Answers
SOURCE: I have a whirlpool GHW9100lw1
entire basket, and the rear half of the outer basket as well( thats where the bearing is located
Posted on Feb 03, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore agitator clutch dog replacemant?
The followng link explans how to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the instructions and let me know if you have any questions. I hope you find this information helpful.
Posted on Jul 07, 2009
Agitator is not turning.
These washers have a set of dogs inside them. Over time the facing of each dog wears smooth. The agitator can be repaired easy enough. Use a socket and extension to remove the agitator bolt and yank the agitator out of the machine. Sit it on the floor and hold it down with your feet. Yank the top portion off and replace the dogs. Take care not to break the tabs on the lower agitator when yall snap the two pieces back together. VIDEO
Apr 07, 2011 | Kenmore 22642 Top Load Washer
Agitator issue (Agitator and not workin properly
The majority of the agitator problems with a whirlpool agitator involve the dogs wearing out on the two piece or dual agitaion agitators. It is simple to pull the agitator off by popping off the top cap and turning the 7/16 inch bolt counter clockwise in the center to release then pull off the agitator .
WIth some force it can be pulled apart to replace dogs, or any service store nearby.(The four little dogs have teeth on them which wear off over time)
Hope this helps.....
Jan 25, 2011 | Whirlpool Washing Machines
The agitator goes around and around, not back and forth. is that what it is supposed to do?
The top portion of that agitator is supposed to push the clothes in a downward motion. Their are four agitation dogs inside that grab the side of the top portion as the wash cycle continues. Over time those dogs wear out.
I have move videos and a manual with more good stuff HERE
Nov 19, 2010 | Whirlpool Washing Machines
Top part of agitator is loose and wobbles and
These are called "dogs" and they are replaceable and do not cost much. Basically, they keep the agitator locked in position when the shaft moves in an oppisite direction so the agitator can step forward.
They should be fairly simple to remove with a phillips screwdriver or a 1-4 in nut driver. take them to a reputable appliance parts store and they will be able to sell you replacements.
These are made to wear out and be replaced so the agitator itself doesnt wear, which is a whole different story to replace. Left-handed shaft screw. Undo it in a clockwise direction and slide the agitator off the shaft if you find that replacing the dogs does not work.
Oct 01, 2009 | Whirlpool Washing Machines
Noise during spining cycle
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 22, 2009 | Kenmore Washing Machines
How do you replace Agitator directional cogs on a kenmore 80 series washer. lower agitator rotates but upright makes grinding noise and works partial of the time as if gears are slipping
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
Jun 13, 2009 | Kenmore 24032\24036 Top Load Washer
The washer will not adjatate the close when washing but when you push down on the adjatater it starts working
The dogs are likely bad.
May 29, 2009 | Kenmore Washing Machines
Hi there, I recently replaced motor belt of top loading Hoover Commander washing machine. The problem is the washing blade is now rotating continuously one way without stopping . It used to stop and turn...
Apr 11, 2009 | Washing Machines
Kenmore 90 series washer continues to agitate on spin cycle making noise while spinning
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Clucth Dog replacements in Agitato
Feb 02, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
