Question about Air Purifiers
Replace 3 way switch on a rug doctor - Air Purifiers
2 Suggested Answers
laseramp
  • 309 Answers
SOURCE: how do i rest the timer on my rug doctor
The reset button is on the top or back of the machine.
Posted on Oct 15, 2012
How can I extend the hose so I don't have to bend so far down when I vacuum. I am tall
You could try wearing the cleaner like a backpack...
I live in a small town and there are at least two businesses here where I could buy vacuum cleaner hose by the metre.
I have also seen purpose-made 1 metre hose extensions.
It isn't always easy but I have repaired and replaced hoses, changed ends and generally managed to use surplus and discarded hoses rather than buy new.
I suggest you approach the sort of business that supplies vacuum cleaners and washers and suchlike to other businesses rather than a high street type shop.
Feb 25, 2015 | Miele Olympus S2120 Canister Vacuum...
Hoover Tempo Widepath: It appears the height adjuster may not be working correctly; while pulling the vacuum toward me the brush skips across the carpet now displaying a diagonal pattern in doing so. I...
Check height adjuster first to make sure that it is still functional. If the brush is too low to rug, it can cause some skipping as you pull the vac. to you. Have you tried to vacuum at a different angle to see if skipping stops? If your height adjuster checks out okay, it could be that your rugs may need a good steam cleaning. I have two dogs, and after awhile, the oil residue from there dander collects in the rug which is unavoidable after a long period of time with regular vacuuming. The carpet starts to mat and that's when I experienced my vacuum cleaner starting to skip. After a good professional steam cleaning of the carpets were performed, the vacuum cleaner stopped skipping. Hope this was informational.
Dec 20, 2014 | Hoover U5140-900 Tempo Widepath Bagged...
When bar light is on level 3 what does that mean holmes air purifier
Hello, this is Ava with Think Crucial.
There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
May 19, 2014 | Holmes Products HAP422-UC Air Purifier
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
The piece on the bottom of the vacumn that controls rug height will not work
I had to use pliars to change the level. I only used that vac three times and I got rid of it. It cut off on me and never restarted. Sorry!!
Mar 05, 2014 | Eureka AirSpeed Bagless Upright Vacuum,...
How do i rest the timer on my rug doctor
Oct 15, 2012 | Rug Doctor Green Formula Oxy Steam Carpet...
Blinking red light above the lowest setting on filter queen defender air purifier.
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 23, 2010 | Filter Queen Defender Air Purifier
Ionic breeze, red over ride light will not go out
The internal high-voltage grid wires are connected to a switch which is maintained in the closed position by the tension on the wire.
This red light comes on when the tension in the high-voltage grid wires relaxes or one of the wires breaks thus opening the switch.
There is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended.
Like you I went through the hard-core cleaning pocess, but found it usually makes no difference or very little.
You could try E-Bay for a replacement or shop for a more rugged ozone-generating air purifier -- I'm looking for one myself.
Charlie
Oct 01, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I have an Ionic Breese Quarda that just stopped working all of a sudden. Is there someone who can walk me through some basic fixes? Company out of business I'm told.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
Charlie
Sep 21, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Breeze just stop running.....
At the rear of the unit is the filter. When the filter is removed, the small screw or whatever it is called, that is attached to the filter on the lower right side, disengages the the safety switch just below the filter on the unit itself, if there is nothing to hold down this safety switch the unit will not operate. So take off the filter, there is a small notch on the unit, inside this notch is the safety switch, Try pressing down on this switch and see what happens. I hope this helps. Also, it may be the fuse.
Feb 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Air Purifiers Logo
64 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
