Question about Frigidaire ATF6000ES Front Load Washer
No get cool
Compresor overheating
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
You wired it wrong to 120 , it should be 240. Vitally
Posted on May 22, 2009
Gimme an idea -- side by side, fridge side not cooling. thanks
check for compresor operation. relay in compresor can fail at times
Feb 12, 2010 | Frigidaire Refrigerators
Compressor low pressure triped
If the compresor, overheats, then compresor it's not good, make sure that there is a safety cycle on. Explain: there should a click when compresor starts if you hear a click again within 30 secs. is a confirmation that the compresor has weak coils, and needs to be replace. If this is not the case, make sure you are not using an extention cord to run this unit, maybe wire are overheating.
Jan 06, 2010 | Heating & Cooling
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Does not cool and compressor relay keeps intermittently buzzing every 1 to 2 minutes. Condenser coils are cleaned and when you check across the overload protector pins there is no continuity.
When there's not continuity across the overload is because the compresor overheated , it could be the relay or the compressor that is burned out or stuck .I would let the compresor coold down for a few hours (unplugging the unit) and replace the relay (no more than $20) and if still having problems the compressor needs to be replaced.
Aug 23, 2009 | Amana Freezers
Everthing sunddenly thawed out how come? whats the fix can i do it my self
If you heard the compresor running and it's not cooling ,probably is out of refrigerant(freon) ,but ifthere's power in the outlet and the compresor isn't working and is hot to the touch ,could be the relay or the compresor went bad ,also if there's power but the compresor is cold it could be the thermostat is open ( you can check it by putting a jumper in the thermostat wires).
Aug 20, 2009 | Frigidaire Freezers
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Not cooling - sounds like something is trying to start then clicks off
Try first replacing the relay(located on the side of the compresor)wich the part won't cost more than $20.If doesn't work the compresor is stuck or burned and you need to replace it.
Apr 19, 2009 | Refrigerators
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Apr 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire ATF6000ES Front Load Washer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
