Question about Refrigerators
Need drain plug assembly for mim-88 mr feeze - Refrigerators
2 Suggested Answers
keneackley
SOURCE: Mr. Freeze Ice maker Model MIM-88
I TOO AM LOOKING FOR THE SYNCHRONOUS MOTOR #50TYZ-E-1. i DECIDED TO DRILL OUT OLD PIN & USE SS COTTER PIN.
Posted on Aug 10, 2012
Remove existing radiator drain plug assembly
if not leaking,leave it alone,to drain,just disconnect bottom hose to drain,I never use drain plug,too slow.If it's a stock drain plug,then you will need to call dealer and ask for parts.
Nov 24, 2013 | 1994 Oldsmobile 88
How to install a power steering high pressure line on a 1998 olds 88 regency
You will need line wrenches to get the line off the steering gear assembly (tight in there near the frame sub assembly) First you will want to remove the drive belt from the power steering pump. Then remove the bolts from pump to bracket and lift pump up. On back of pump, remove low pressure line and drain fluid into a container. Under pump, remove high pressure line, and push it downward toward floor. From under car, follow the line to the steering gear, ( the line may have a keeper clamp or two for stationary support to remove along the way) then detach. Installation is reverse of disassembly........Not fun, but doable.....Mike
Jun 22, 2011 | 1998 Oldsmobile 88
Dec 21, 2010 | Vacuums
Where is the oil drain plug on the 88 c.i.H.D.2003
On all Softail models, look along the bottom of the oil tank from the right side of the bike. You'll see a line or hose going downward towards the transmission. Usually, unless the changed something, the line will come out along the frame down below and behind the transmission. There will be a plug in the end of the line. Remove the plug to drain the oil.
Good luck
Steve
Jul 21, 2010 | 2000 Harley Davidson FLSTS Heritage...
Where is the oil drain plug on the 2003 dyna 88 cubic inch?
Since a Dyna's oil tank is on the bottom of the transmission, so is the drain plug. There are two drain plugs. The one on the left side is the oil drain. The one closer to the center is the transmission drain plug.
Oct 07, 2009 | 2003 Harley Davidson FXD Dyna Super Glide
Have a Mr. Heater 175000 BTU that is leaking at the bottom were the drain plug is located. The O-ring is cracked, I need a replacement for the O-ring. What size do I get?
Tip the heater up so that the fuel is away from the drain plug hole and take the plug to an auto parts store. They have bulk o-rings there and can fit the needed O'ring to your plug.
I checked the parts manual:
http://www.mrheater.com/upload/newsletter/mh_50_75_125_150_175_210_BL.pdf
There is no drain plug listed for the tank. Only the tank assy. (Item 2)
You might even be able to get a copper crush washer similar to what is used on an automobile or motorcycle oil drain plug.
Kelly
Sep 30, 2009 | Mr. Heater MH175KT Open Flame Utility
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
