Code for a remote control
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Remote
control codes:http://www.xdiv.com/remotes/
http://www.remotecodelist.com/remotes/rca/rca.htm
