Question about Apple Cinema Display 23" HD Monitor
Broken power connector
Any idea where to get a replacement connector for the special power lead used with this monitor? Everything is ok with this monitor except some idiot knocked into this lead plugged into the "white brick" and smashed the plug.
  • 6 more comments
  • skifan Oct 24, 2007
    A white lead comes out of the back of the display and splits four ways going to a USB connector, a Firewire connector, a DVI connector and a special 'Apple' 12-way connector which goes to the "white brick" - this is the one I'm talking about.
    Apple authorized technician says that the monitor is a "write off" and the warranty is void - but I can't believe that I have to throw it away just because one plug has broken! How eco-unfriendly is that?? Surely someone makes replacement plugs?
    It would be a big improvement if Apple made this connector recessed inside the "white brick" like the mains power connector on the Mac itself ... I wish ...
    Does anyone know how to open up the "white brick"?
    Oh!
    By the way, do you know how to open up the monitor itself?
  • guiguiadams Nov 26, 2008
    My cat chewed up one of the 4 splits at the end of this cable. Apple is charging U$ 480.00 for repair, but I am sure there must be a cheaper/easier way. Anyone?
  • Mac Lad Dec 05, 2008
    I have the same problem. I explained to Apple that it may have been a manufacturing fault that went unnoticed but over time degraded and broke when I was tidying up and rolled my workstation back in place and that's when it gave way.
    I've been to the Apple retailer who had a looked and then told me to contact the customer relations department who tried to see if they could replace it. Unfortunately, they couldn't because of the way it looked on the photos.
    The other option is to claim it on home insurance
  • Anonymous Dec 05, 2008
I do, but it's not reccomended, and it severely dangerous as you would have to discharge the display...which if you decide to do, may lead to ingesting High voltage....not reccomended.
Posted on Oct 24, 2007
    Novelist:
    Champion:
  • 382 Answers
If its the lead that separate4s from the monitor, then the Apple store. If not, try an authorized technician.
Or try....
http://www.welovemacs.com/apmosepa1.html
hope this helps.
Posted on Oct 21, 2007
  • Keith Seekwhensir
    Keith Seekwhensir Oct 24, 2007
    Opening the brick is the converter/PSU. I am an auhorized apple tech, and they dont give us instructions......It;s leathal even unplugged.
How to fix code po500 on a 2001 ford ranger
A code P0500 may mean that one or more of the following has happened:
  • The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
  • There is a broken/frayed wire leading to the vehicle speed sensor
  • The vehicle's PCM is not correctly configured for the actual tire size on the vehicle
check all wiring and connectors that lead to the speed sensor. The location of the sensor depends on your vehicle. The sensor could be on the rear axle, transmission, or perhaps the wheel hub (brake) assembly.If the wiring and connectors are OK, then check the voltage at the speed sensor.
If everything looks OK, replace the sensor.
Sep 06, 2014 | Cars & Trucks
I got power to coil nothing comes out of coil
if you have power to the coil the only things that can be wrong are: -
1. the coil is duff.
2. The HT lead is broken.
3. the plug cap is duff, broken.
Remove plug cap and see if there is a spark from the wire core when the lead is placed near the engine/frame.
If it sparks OK replace the plug cap,. no spark means either the coil or the lead are duff. If you can replace the lead try testing again without the cap. Hope this helps.
Jul 31, 2014 | 2005 Yamaha V Star 1100 Classic
I cannot see display in my screen it is full black
Disconnect the power and VGA cable from the comp. and monitor and wait for 2 minutes
Press and hold down the POWER button on the monitor for 1 minutes and then connect everything directly.
It shold work if the CRT gun of the mnitor is OK otherwise u may hv 2 install drivers.
Jul 11, 2010 | Samsung T220HD LCD Monitor
There is no power to the monitor,it is not coming on when i start up computer
If the AC plugs directly into the monitor, try reseating the power cable or replacing. If the monitor uses a power supply (ac adapter brick) check that the power cable is fully inserted in the brick and the dc connector is fully plugged into the monitor. Also check the dc connector for bent or broken pins.
Mar 24, 2010 | Computers & Internet
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Get acer logo then windows for a second then
If it was dropped in all probability it is broken. Perhaps your friend would share the cost of replacing it. sorry for your loss
Jan 01, 2010 | Computers & Internet
My HP a420n was working fine.To replace the cd-rw drive with a dvd-rw drive I turned the computer off, removed the power cord and replaced the drive (I wore an anti-static wrist band). I then pushed the...
there is a possibility that you may have pulled off the power switch, to motherboard Connector.
This will be at the bottom right hand-side of the Motherboard.
You should have a 2 cable connector for. pwr/sw Power Switch. hdd/led Hard-Drive led. rst/sw reset Switch.
Check those First. if you didn,t remove the power lead, before attempting any work. you may have arced a current, and damaged the motherboard Or PSU. check the Fuse In The Actual plug lead. to determine the actual power Switch, without a multi-meter. remove the power lead, from the Computer. remove the power/sw connector From motherboard, And Bridge the power/sw with A plastic jumper Block. then replace power lead, and should boot up. If it does the fault is the actual power switch faulty.
Mike @ Compurepair.
Oct 22, 2009 | HP Computers & Internet
Black monitor no power
Hi. On some motherboards the 'Enable usb Support' option in system can cause this. Use a conventional ps2 mouse and keyboard, unplug all usb devices, enter system and ensure that 'Enable USB Keyboard Support' is turned off and continue setting up as usual. Try locating a bios upgrade for the mobo concerned.
I hope this helps. Let me know how you get on.
Apr 25, 2009 | Computers & Internet
DESKTOP COMPUTER TURN ON PROBLEM
In this case it is normally a voltage regulator near the cpu that is shorted and will need to be replaced.
Remove everything from the board, except the heat sink fan and plug in the big power connector, do not connect the 4 pin connector. Turn the power on as you were before.
Using a multimeter, check the voltages on those regulators. You should find them running in pairs normally, but make sure to check all of them and try to pick the odd one out.
Put your black lead to ground, and use some electrical tape to cover all of the red leads probe except for 2mm at the tip to help prevent shorting out anything else while you are there.
Apr 08, 2008 | Intel Motherboard
Apple Cinema Display 23" HD Monitor Logo
174 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
