Question about Honda 94-95 Accord Tcu Tcm Transmission 28100-p0h-a02
Gear stuck third
My son has a 1994 Honda accord and he replaced the clutch thinking that was the problem . But now he saying its stuck in third gear, But even with the wheels off the ground it will kill the engine when he lets out on the clutch like something is locked up. what should he do to fix this problem?
  • 468 Answers
It is probably the transmission. With the wheels off the ground rotate the wheels back anf forth. While trying to shift transmission out of gear. If that does not work try removing shift linkage and try to move individual shift levers to try and unjam transmission. If all else dails replacement may be the answer. Hope this helps.
Posted on Jan 04, 2014
94 Honda Accord Manual transmission not shifting into gear while running
have you checked the fluid in the clutch master cylinder?
Mar 31, 2014 | 1994 Honda Accord
94 Honda accord Manual transmission not going into gear
Rodney, sounds like a clutch problem to me, pressure plate is likely not releasing.
Mar 30, 2014 | 1994 Honda Accord
Why wont 1994 1100 shadow shift out of third gear
Change the gear shifter 2 teeth UP or DOWN.
Otherwise, these models are known for problems with third gear (gear dogs and shifting fork get worn out, hard laser welding is a solution)
Mar 13, 2013 | Honda VT 500 C Shadow Motorcycles
1994 Honda VT 1100 C Shadow will not shift
Hi, Ronnie and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Second gear is not my best friend
Bleeding out clutch master 87 Honda VT1100
Honda SHADOW VT1100 Owners Workshop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 26, 2013 | 1994 Honda VT 1100 C Shadow
Can shift gears not started, but once engine is on can't shift
auto or manual would help, i would say clutch in a manual or damage to auto gear box or torque convertor if automatic. manual is a cheap fix auto may be thousands.
Jan 17, 2013 | 1994 Honda Accord
I have a 97'honda accord and I thinks it's my
could be that clutch needs replaced or problem in shifter......
Aug 22, 2012 | 1997 Honda Accord
1994 honda accord shifter stuck
Check clutch fluid, must be low. If not this, then do clutch adjustment.
Sep 03, 2017 | 1994 Honda Accord
Hello i have a 1994 honda accord sir cd6 h22a engine my problem is every time i change into 5th gear it grinds
Hi and welcome to FixYa!
Pretty much a worn out clutch lining. If the clutch lining is worn out, it tends not to stop the flywheel and will surely cause a grinding sound.
I strongly suggest that you replace the clutch lining, pressure plate and release bearing to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Mar 03, 2011 | 1994 Honda Accord
Honda 94-95 Accord Tcu Tcm Transmission 28100-p0h-a02 Logo
76 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
