Why wont my 1/4 ton ajax transmission jack hold a transmission
I have a 1/4 ton ajax transmission jack that will not hold a transmission, what do i need to do to repair it?
  • 1,511 Answers
Get a repair kit, install the parts, fill the chamber with fluid, and tighten the nut so noting leaks. Or get a new Jack.
Posted on Jan 16, 2014
Instalation an removal of a manuel transmission clutch plate
Hey Karen,
This is not something that a novice mechanic should under take,,, you will need: (NEVER get under a vehicle with ONLY a jack holding it up!!!)
2 sets of Duralast 4 Ton jack stands 80505T Read 1 Reviews on Duralast 80505T
transmission jack: Transmission Jacks
clutch pilot tool... Clutch Pilot Alignment Tool
Adjusting tool: OEM Self adjusting clutch tool kit 27209 Read Reviews on OEM 27209
You will also need a service manual for your particular vehicle!!
This is a job for someone that has done it before.. is it a hydralic clutch.. total manual... so many questions.. Think about this before you start.. Get a quote from a REPUTABLE PROFESSIONAL before you start!! -
Jun 19, 2017 | Cars & Trucks
How to remove oilpan on 97 firebird 3.8 liter
The Engine needs to be lifted up 5" so the pan can be slid out around the crossmember.
Nov 07, 2013 | 2000 Pontiac Firebird - 3.8 L V6, with...
Transmissionin a 1946 ford 1 ton will not comeout from the clutch
clutch stuck to drive rod at front of transmission take a pry bar and gently wiggle trans mission away from clutch
Aug 14, 2012 | Transmission & Drivetrain for Ford Transit...
I need steps of removing a transmission from 1981 chevy tow truck
  • Remove the TV cable or transmission throttle cable from the carburetor or throttle body. Remove the upper bolt holding the transmission dip stick but do not remove the tube. Disconnect the negative cable to the battery. Drain the transmission fluid by removing the transmission pan. Replace the pan after draining the fluid.
    Remove the shift linkage and the wires to the neutral safety switch. Remove the speedometer cable by unscrewing the cap at the point it enters the drive gear in the tailshaft. If it has an electronic speedometer, disconnect the electrical connector.
  • Install the engine support stand above the engine. Remove the CV joints. Remove all electrical connectors from the transmission. Remove the bolts in the torque converter. Place the floor jack under the transmission. Raise the transmission just enough to support it. Remove the transmission mounts. Lower the transmission enough to have access to remove all the transmission bolts. On a rear wheel drive vehicle, remove the bolts in the bottom of the transmission mount. Raise the transmission enough to remove the cross member.
    Once the bolts are out remove the cross member and then lower the transmission. Remove the dip stick tube from the transmission by lifting up. If it is hard to come out tap its mounting bracket with something and it will come up and out. Support the transmission securely on the jack. Using a flat head, separate the transmission from the engine. Lower the transmission.
    hope this helps
    but you can also just pull the motor and trans for better access ive also got an 85 chevy im about to do some work on ganna pull and rebuild the motor which is a first for me so if u know any one i could also get some tips from help would be awsome thank you
Nov 10, 2011 | Honda Cars & Trucks
How hard is it to change the clutch
on the ground it is a real pain, about 6-8 hours, suggest u buy a factory service manual, u will need a good full set of all types of hand tolls, a hydraulic floor jack (min 2 1/2 ton). safety jack stands and a helper is absolutely needed to get the transmission back in.
May 29, 2010 | 1997 Saturn SL
How do you remove the front drive shaft in a 1999 Chevy 1/2 ton 4X4?
Jack up front end, and put on stands. Remove wheel. Remove large nut on end of drive shaft. Remove lower control arm, from wheel hub bearing assm.
Push drive shaft back toward transmission.
Now that drive shaft is free, you must "pop" it out of transmission output.
You can use a pry bar, but be careful not to damage anything.
Apr 15, 2010 | 1999 Chevrolet Silverado 1500
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
4L60E transmission
rebuild the original, a 95 wont and cant work, and it a 2 wheel drive if the shaft is too long... www.TransmissionGarage.com
Dec 29, 2008 | 1995 GMC Suburban
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
