Honeywell thermostat th4000
Ac and fan work . Heat doesn't work
    Problem Solver:
  • 5 Answers
Hard wiring on newer t-stats calls for a jumper from R to Rh. If that doesn't work, or isn't the problem then check for 24V at the unit board from W to common. If you have 24V there the stat isn't the problem. I don't know if your heater is gas or electrical, so there's not much else to say.
Posted on Jan 04, 2014
Testimonial: "Heat pump"
  • 1 more comment
  • Jonas skol
    Jonas skol Jan 04, 2014
    Just changed thermostat and unit was working fine before
  • Jonas skol
    Add a Comment
  • Jonas skol
    Unit has a built in jumper between r and rh. Also I tried afterwords to jump the first two
chillmaster
  • 104 Answers
SOURCE: I tried to replace my
Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. This is all for a heat pump, If you do not have a heat pump, then disregard the references to "O", "B", "E", and "aux". You will have R-power on red wire, W-heat signal to furnace, G-fan signal to furnace, and "Y" cool signal to outdoor unit.
Posted on Jun 15, 2008
22yooper
  • 828 Answers
SOURCE: We have a Honeywell Chromotherm
I almost think you have no power source to the thermostat as if the power is off to the air handler unit (furnace), or the 24 volt transformer is bad. Could well be that the error codes are being powered by the battery.
Posted on Jul 24, 2008
  • 182 Answers
SOURCE: honeywell th4000 thermostat - fan
That problem is seldom the thermostat.check all fuses and breakers....if they're ok,its prolly an internal problem to the furnace.
Posted on Aug 24, 2008
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
  • 1238 Answers
SOURCE: Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
Posted on May 11, 2009
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
I have Honeywell Pro TH4000 series. The fan will not come on what do i do
It really depends on the circumstances. Are you just trying to turn the fan to the "ON" position from the "AUTO" position? If that is the case, there will be a problem with the thermostat, wiring to the thermostat, or the unit itself. That would sum up a "thermostat" problem for the fan not working. If your trying to call for HEAT/COOL and the fan isn't coming on, that is another issue.
You can try to see if the G terminal is hooked up on the thermostat, that's going to be your "FAN" terminal. If it is connected, you will have to go to the unit and see where it is connected. At this time, we would need to know the model and manufacturer of the unit. Thanks, hope it helps.
I have a pro th4000 series honeywell programmable thermostat and its for system type th4110d electric heat with ac how do i set the thermostat to drop a few degrees before the heat turns on right now i got...
this thermostat does not have a deadband option, the only other thing you can do is set the program for a different temp. the cycles per hour just restrict how many times the unit comes on.
Dec 15, 2009 | Coleman Heating & Cooling
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell th4000 thermostat - fan won't come on. The system set to cool and the temp is set lower than room temp.
Aug 24, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
