Question about Plantronics M100 Bluetooth Headset
M100 bluetooth headset too low suddenly
I've had this headset for two years and have never had a problem with it. Recently one of my chargers would not charge it completely and it would blink red after a certain point. It chargers normally on other chargers. Recently when I turn it on the volume is extremely low. When I make it louder on both the phone or the headset it maxes the volume but sounds like the lowest volume normally. The lowest can no longer even be heard. I know this is an older model now but any suggestions or is it time for a new one?
    New Friend:
  • 3 Answers
You can get a voltmeter at any auto parts store that will test the output from your charger , and will also check the resistance out to the phones .. if the charger is charging to the stated voltage , and the batteries are not charged , they need to be replaced , their only good for 2--4 years , the chemicals , after time , lose ions in the charge/ discharge process. good luck..
Posted on Jan 04, 2014
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Posted on Aug 28, 2008
SOURCE: forgot how to sync my
Hold the up volume and the talk button (the one on the side of the ear piece) down until the status light flashes red then blue.  This places the headsead into pairing mode.
Posted on Jan 06, 2009
keekus
  • 83 Answers
SOURCE: outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
  • 5 Answers
SOURCE: headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each other....it will send you a screen to enter a code. This will be 0000.....enter that...and once they pair...you are good to go.
Posted on Mar 08, 2010
SOURCE: plantronics discovery 925 will not stay on after a full charge
I'm having this same exact problem man!!
Posted on Mar 17, 2010
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Itunes isn't playing in my headset
It is because Plantronics M100 Bluetooth Headset does not support A2DP, without A2DP you can't stream music
Oct 18, 2012 | Plantronics M100 Bluetooth Headset
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Apr 17, 2012 | Jabra BT3030 Bluetooth Headset
Plantronics m100
I don't know if you've done this, but before charging the headset, you want to turn it off. On the "Take A Good Look" page from the link below for the Plantronics M100 you'll see how to turn it off. If it's still not charging right, you may need to take it back to your retailer for warranty replacement or call Plantronics at 800-544-4660 x5 x5538 for warranty assistance.
Plantronics M100 User's Guide
Good luck from Headsets Direct!
Nov 16, 2011 | Plantronics M100 Bluetooth Headset
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Good luck from Headsets Direct - 800-914-7996.
Aug 04, 2011 | Plantronics M100 Bluetooth Headset
I have a Toshiba TG01 phone and a Plantronics M100 earpiece. My problem is that when i use the earpiece, and my Toshiba phone the other person with who i speak with, can't hear me well. It hears me...
This model headset is one of the headsets rated as compatible with your phone. You want to make sure there are no other bluetooth applications interfering with the link. Disconnect the phone battery, if possible, for a few seconds and reconnect. Then re-pair following the instructions on the link for the Plantronics M100 bluetooth headset.
Jul 14, 2011 | Plantronics M100 Bluetooth Headset
I am trying to charge my Plantronics M100 blue tooth. I will not charge and the light is flashing red continuously.
If headset does not charge and light blinks red continually, it is defective and will need to be replaced. It comes with a one year warranty. Call Plantronics at 1-800-544-4660 x 5538 for assistance.
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics M100 Bluetooth Headset
My plantronics m100 bluetooth sys its connected to phone but dont work.
Try to re-subscribe or pair to cell phone again. You will have to go into the tools or settings on your phone to remove bluetooth device. Then start the subscription over.
Here is a link to the User's Guide.
Jun 06, 2011 | Plantronics M100 Bluetooth Headset
Plantronics M100 Bluetooth Headset Logo
99 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
