Question about Optics
Krico rifles, trigger
How to adjust trigger weight
2 Suggested Answers
  • 4 Answers
SOURCE: I have a beeman rs1 chinease air rifle is the
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here http://webpages.charter.net/guru1/documents/RSE%20Airguns%20-%20Beeman%20RS2%20trigger%20guide.pdf
Posted on Aug 18, 2010
How can I adjust the trigger pull?
Hello, here is website for adjusting the trigger:
How to Adjust Adjustable Triggers
Please rate my answer, give me thumbs up , pls, thank you.
Nov 30, 2015 | Optics
How do i adjust the trigger pull
Very carefully as if you get it wrong
Most rifles come with limited adjustment to the trigger pull down to 5lbs if you are lucky so to get them lighter say to 2.5lbs final stage you either have to get a after market trigger or
Stone the surfaces of the trigger but doing this is very very dangerous if you make a mistake
Take the weapon out of the action and look at the trigger for small screws or Allen bolts that adjust the sear engagement and if the trigger has them adjust them a little bit and test trigger pull and safety catch to see if it dry fires when you operate the safety if every thing goes OK repeat until you get desired pull weight or run out of adjustment then think about a professional trigger job as if you get it wrong you will start putting rounds in unexpected places
I have gone on about getting it wrong a lot as I have seen weapons with truly hidious trigger jobs that have fired by closing the bolt or setting the safety to safe which has given the other shooters a nasty surprise and the poor nut on the gun a shock
Jun 09, 2015 | Miscellaneous
How do I adj. the trigger pull on my wetherby .204 cal. rifel
If it came with an adjustable trigger easy to do take action out of stock and check trigger for adjuster screw should have +/- arrows and don't go below 16 oz pull
if not the rifle will have to go to a competent gunsmith or to a wetherby service centre to have the trigger faces honed
Or fit an aftermarket adjustable unit like timney
Feb 21, 2015 | Optics
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
I have a 2003 flstci and I'm trying to adjust the rear shocks. Do I take the weight off the back tire or leave the weight on the back tire to adjust them.
The bike should have both wheels on the ground when you adjust the shocks. If you're adding weight to the bike, you can still adjust the shocks with the additional weight onboard but the adjuster will turn easier if the extra weight is not there.
Jun 26, 2011 | 2003 Harley Davidson FLSTC Heritage...
I have a .45 ACP Norinco hand gun. The trigger is over 7 lbs pull. I want to adjust it to a lower weight. How do I do it?
See the link below. Be careful because this can be VERY dangerous and will most likely void you warranty.
http://www.ehow.com/how_5896568_adjust-trigger-pull.html
Jun 03, 2011 | Computers & Internet
I have a beeman rs1 chinease air rifle is the trigger adjustable and if so How?
Mar 21, 2010 | Beeman Optics
What are the functions for the three screws in the trigger guard of the Beeman RS2 Sportsman?
The larger screw controls the pull weight, that is how many pounds weight on the trigger.
The front smaller screw controls the length of the first stage, whether you want a short first stage or a longer one.
The rear small screw controls the lenght of the second stage which can be reduced to zero.
Feb 16, 2010 | Beeman Optics
Feeder motor on hh135 works fine with constant trigger pull but slows to stop when you work trigger
Check the wire feed does not become obstructed when the trigger is pulsed. The wire can become tangled on the roll if it is able to get loose. The reel tension must be adjusted as the weight of the roll decreases.
Nov 23, 2009 | Welding Tools
Optics Logo
20 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
