Question about Kirby Ultimate G Bagged Upright Vacuum
No power kirby sentria wont power up no sound or light nothing
  • 111 Answers
There should be an onboard fuse for the Kirby vacuums. Look on the bottom of the motor. Hope this helps.
Posted on May 22, 2009
Kirby g10d, I shampooded the carpet then put it back together and it wont start 4/12 yrs old used approximately 50 times. Any ideas?
Make sure the emptor at the. Bottom of the bag assembly is turned all the way clockwise. It pushes in on lever on the switch. It won't run if the lever is not pushed all the way.
Jan 31, 2015 | Kirby G10 Sentria Vacuum Cleaner...
How to replace a switch in a kirby sentria vacuum
you need to find your nearest Kirby service dealer as its got a lifetime guarantee and when they fix it for a fee they will go over it to make sure there is nothing else wrong with it.
Jun 26, 2014 | Kirby G5 Bagged Upright Vacuum
My Kirby Sentria is not picking up with the power it normally does. Is there something I can do to correct this?
http://www.ebay.com/gds/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING-/10000000003800312/g.html
May 20, 2014 | Kirby Sentria Upright Vacuum
Kirby sentria 2
Make sure the belt is the right size.. It should be very very tight.
Apr 16, 2014 | Vacuums
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
I cant find fuse on my kirby sentria. Any suggestions?
there isn/t a fuse if not turning on probably a bad switch or power cord
Jul 18, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
Mar 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria
When you replace the outer bag assembly, you have to make sure that it is turned clockwise untill it fully stops. There is a small switch on body of the Kirby that is only engaged when the bag assembly is installed correctly
Jul 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
245 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
