Question about Sony RMYD028 Remote Control
How do I get out of WIDE mode? - Sony RMYD028 Remote Control
    Top Expert:
  • Sony Master
  • 74,136 Answers
Refer its user manual for details.
Posted on Jan 04, 2014
How do I change to 4:3 aspect setting on sony kdl40ex500
If the WIDE button on the remote control isn't changing the aspect ratios here is what I can tell you:
Normal is not available when you are watching a 720p, 1080i or 1080p source.
If 4:3 Default is set to anything but Off, the Wide Mode setting changes only for the current channel. When you change channels (or inputs), Wide Mode is automatically replaced with the 4:3 Default setting for 4:3 sources. To retain the current Wide Mode setting as channels and inputs are changed, set 4:3 Default to Off.
4:3 Default is not available if Auto Wide is set to Off.
The owner's manual can be found here: https://docs.sony.com/release/KDL32FA600-EX301-EX400-EX401-EX500-EX501.pdf
If you still can't get the aspect ratio to properly work you may need to do a power reset or perform a factory reset: https://us.en.kb.sony.com/app/answers/detail/a_id/38403/c/65,66/p/61659,62766,63066/ Just make sure to note any special picture or sound settings you may have made.
Aug 22, 2014 | Sony BRAVIA KDL40EX500 40-inch Class...
Would like to record in 16:9 ratio but am not sure of the results? goof or bad?
You may record in either wide-screen or normal mode. If you record in wide-screen mode, the video will appear compressed when played back on a normal TV. For full details refer to the "Using the wide mode" section of the manual on page 32 of the manual.
May 03, 2012 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
When on wide mode there the full screen is not
This is very normal not all channels are HD some programs are taped like that will not fill your screen like dvd movies are.
Nov 18, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
MHG07A wide lens, cd300, best settings?
I don't have that camera, but try Macro mode instead of Conversions Lens in setup. If the camera focuses (at Wide setting), then you should be able to get down into the wider apertures.
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
What is the difference between wide and standard on a picture?
You will see more detail in highlights and shadows (i.e. if you are a few stops over exposed, you will still see the details of a white wedding dress. If you are a few stops under, you will see the details of the shadows of large canyons on the beach) using the wide feature. The wide mode is used to obtain a larger dynamic range with the S3. The standard mode uses the same dynamic range as the S2. If you are looking for faster write speeds, you would use the standard mode, as the wide mode takes longer to write information. Standard is also used to obtain a smaller Raw file size. Based on the scene being shot, only a photographer would know if he would need more dynamic range then usual. It depends on the highlights and shadows of the subject or scene.
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Sony RMYD028 Remote Control Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
