Question about Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt charger will not charge and red light blinks fast with 6 differant batteries
Dw9104 & dw9116
tcraignfam
  • 30 Answers
SOURCE: Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Posted on Dec 12, 2009
emissionwiz
  • 75815 Answers
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
SOURCE: My Dewalt 7.2-18v charger model #dw9116 is giving
It means there is too high or too low a voltage coming into the charger. Check your chord.
I had the exact same problem. After using the necessary security bit to crack mine open, I found that the large capacitor inside had come loose and needed to be re-soldered.
That fixed my charger.
Posted on Aug 28, 2009
  • 391 Answers
SOURCE: CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Posted on Jun 18, 2010
emissionwiz
  • 75815 Answers
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
Posted on May 18, 2011
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 | Drills
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
I purchased a new DeWalt DW1916 Battery charger and when I install the battery for charging, the red light on the charger blinks on and off and after an hour the battery was still discarged.
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
Oct 01, 2010 | Garden
CHARGER PROBLEMS
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
My DeWalt DW9116, battery charger lead light is fl...
Brown
Brown
Silver
Gold
R21 = 0.11 Ohm at 5 percent
Now can someone help me find the schematic for this model? DW9116
ivanhovideo@gmail.com
On 3/5/12
May 21, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
I purchased a new charger for my Dewalt Cordless drill and the red light just blinks. Is this normal
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
Apr 25, 2010 | Dewalt Drills
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Nov 22, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
104 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
