Question about Vehicle Parts & Accessories
Won't which from top heat to bottom - Vehicle Parts & Accessories
    New Friend:
  • 4 Answers
Can you feel the dial switch or does it seem to float or slide from one end or side to the ther cause mine was the dial itself that lost its inner pin. Hope it helps
Posted on Jan 04, 2014
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
The bottom element won't heat
What is the complete model number of your unit?
Dec 08, 2012 | Kitchen Ranges
Bottom element won't heat up
What is the model number of the unit?
Nov 28, 2012 | Kitchen Ranges
Cook top won't work and oven won't heat
check the plug it sounds like the plug is not secure only getting one leg of current push in firmly
Jul 29, 2012 | Maytag MER5775Q Electric Kitchen Range
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
I used my frigidaire self cleaning setting for the first time. It cleaned the oven well, but now the oven will not heat up properly.
useing a flashlight look over the elements top and bottom you are looking for a type of damage like bubbles or brakage , get back to me Frank
Dec 15, 2011 | Frigidaire Professional Series 24 in....
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
I have a double oven top one stopped heating up sooo i just switched the elements from the bottom to the top as to order the parts but that isnt the problem the top still won heat up
This could be a faulty circuit or sensor that will need to be replaced before the oven safety feature will disengage. If the Temp sensor is not registering as working or the load sensor it will not allow the element to heat up. This is a safety feature. You will need a repair tech to diagnose this and do the repair.
Oct 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
