Kerr heat pump not working,showing P3 code - Heating & Cooling
Electric motor pump makes a burr sound then blows fuse
Sounds like the motor is stuck or froze. If possible, unplug it and try turning it back and forth by hand.
Mar 19, 2016 | Global Industrial 2 Nylon Transfer Water...
How do you replace pump? i took the 4 bolts out and drained the oil but pump is stuck to the cam. whats holding it on?
With most pressure washers the pump is also secured to the crankshaft using a setscrew. Check around the pump flange. You should find a small hold or slot in it somewhere around its radius. You will then need to slowly crank the engine until the setscrew is aligned to the opening. They are normally allen head setscrews but they vary in size. Once you remove the setscrew it should slide off the crank. Sometimes they will still stick on and will require some prying to remove them. In rare instances the cranks can rust together and require heat in order to be freed from one another.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Dewalt 3800 PSI Pressure Washer
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Whare can i get a pump head for a karcher hds 1000 de
I work for one of the top Karcher dealers in the US and we can get this part for you. Visit our website at www.landanw.com for contact info or call 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Feb 26, 2011 | Karcher 2500 PSI Pressure Washer
I have a kenmore elite model#11062982100 turns on runs, timer no problems. it just doesn't heat up i checked the heater relay 47vdc @p3-1 to p3-2 and 0vac @com to no
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Whining noise constantly coming from engine
read post by van kerr ,also water pump bearing/cam tensioner bearing/power steering pump /clutch thrust bearing
Jan 07, 2009 | Renault Sport Cars & Trucks
GE Microwave JES1334WD Code -P3-
Are you sure it's not F3? That would be a shorted keypad ("membrane panel").
That's usually not too big a job for a DIYer, but if you'd like, we can do that for $39.95 plus parts.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
One good test is (with power unplugged) to unplug the keypad, then plug the oven back in and see if the error code shows up.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
