Bad paper jam - Office Equipment & Supplies
    President:
  • 2,923 Answers
As I understand, you are having a paper jam problem on your printer. But, what is the brand and model number of your printer? Are you getting an error message? Did you try removing the paper out of the printer? Are you still getting an error message even if there's no paper in the printer?
Since I don't know the model number, here, I provided you the link that might help you resolve the problem:
http://images.google.com.ph/imgres?imgurl=http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c00723187.gif&imgrefurl=http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument%3Flc%3Den%26dlc%3Dhr%26cc%3Dhr%26docname%3Dc01121731&usg=__EnksKGuxzIZiZrLwwXaAHW6846M=&h=254&w=300&sz=15&hl=tl&start=5&um=1&tbnid=yO8GkuvX8_3XVM:&tbnh=98&tbnw=116&prev=/images%3Fq%3DClearing%2Bpaper%2Bjam%26hl%3Dtl%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:official%26sa%3DN%26um%3D1
There's a step-by-step procedure with illustrations.
Have a great day!
Posted on May 22, 2009
How to clear paper jam 11 paper is cleared but still indicates that its a jam
Then properly the sensor near the jam had it accurator jammed so the copier thinks there is still a paper there. or you mite have paper dust or dust blocking the sensor. Could also be a bad sensor worst case bad main board.
Aug 14, 2014 | Konica Minolta bizhub Office Equipment &...
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Paper Jam Fuser 077-104
Most likely you will have to replace the fuser. Also I would inspect all pick up rollers and make sure they are all textured with no smooth or bald spots. Bad rollers are the #1 cause of jams. Also if you hear any clicking you may have a bad gear.
Jul 13, 2012 | Dell 3100cn Laser Printer
I had a paper jam and cleared but I still get the paper jam message. I cannot see any evidence of paper.
Where was the paper jamming at? On this model printer there are several things that could cause a jam or false jam. You paper pickup roller or sensor could be be bad, The fuser could be bad and prevent the paper from pulling thru or one of the paper ath sensors could be failing giving a false trigger. If you would like to call us at 318-769-9040 we would be glad to help you.
Corporate Computer
www.ccl-la.com
Aug 17, 2010 | HP LaserJet 4 plus Printer
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
The paper twists when feeding into the printer
If this is happening from the paper tray, you probably could use a new set of rollers for the tray. Also, have you had any paper jams where when you cleared the jam there was some paper missing? We have seen useres clear jams and leave a little bit of paper in the printer which blocks the paper path causing the paper to twist in the path as it hits the jam piece of paper. If the jam is a little after the pickup area you could have a bad registration assembly which is immediately before the area where the paper picks up the image. If this is happening at the exit, it could be a bad fusing assembly.
Oct 19, 2009 | OKI C5100n Laser Printer
My lexmark is jammed
did you have any jams recently where the paper was badly damaged, and or came out in pieces? If so there may be a small amount of paper still jammed in the printer, out of sensor range. try looking deep into the bottom of the paper path and around the roller.
Feb 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
21 people viewed this question
jasbo
jasbo
