Question about Sharp Insight Series : KB6002LS 1.0 cu. ft. Built-In Microwave Drawer - Stainless Steel
Change bulb sharp insight kb6002ls - Sharp Insight Series : KB6002LS 1.0 cu. ft. Built-In Microwave Drawer - Stainless Steel
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Light stopped working
I gather that you have checked the bulb with a meter to see if it is bad. If it is xenon high intensity then they have a short lifespan because of the heat. If that is not the problem check the batteries with a meter to see if they are good and if they are, replace the switch.
Apr 14, 2014 | Insight Technology M3 Tactical Illuminator...
How do I replace the light bulb in a Sharp R-308KK microwave?
Google the model number with "how to change bulb" and there are some with video instructions on You Tube the Google searches should also bring up.
Nov 07, 2012 | Sharp R-308KK / R-308KW 1100 Watts...
Change lightbulb
You must remove the cabinet shell, it is held on by sheet metal screws, remove them all the bulb is inside.
Jun 29, 2012 | Sharp Microwave Ovens
Where can I buy a Sharp drawer microwave in the UK?
Hi
You can check out these links to buy Sharp Microwave in UK:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Mar 18, 2011 | Sharp Insight® KB-6002 1000 Watts...
How do i change light bulb in sharp carousel R-320HQ microwave oven?
open cover and
change bulb
before open it turn off woven at last 30 minutes
Jan 30, 2011 | Sharp R-320HQ Microwave Oven
How do I change the light bulb on my sharp R-530BS
You have to remove the shell. Screws are in the back and may require special tool (torx, security). Be certain to remove power and be very careful as the shell will have many sharp edges. The bulb is along the right side (as you face the oven opening). It is a specialty bulb you will have to order from an appliance parts house (or try e-bay).
Apr 15, 2010 | Sharp R-530BS Microwave Oven
Purchase debate ie: lanier v. sharp copier
As one retired from that industry, my choice between those would be Sharp; Lanier support is much inferior to others. If you have a service company in your area, I can also recommend Canon and Toshiba as reliable machines. The best built copier of them all (IMHO of course), is Minolta but they are hell on wheels when they do need service and their support for their units is tightly controlled and independent service companies are pretty much shut out of parts procurement or ripped off in price.
Modern cartridge-based machines aren't nearly as service intensive as earlier but it is still wise to check on local support before choosing.
Apr 08, 2009 | Sharp AR-M205 Copier
Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
Jan 12, 2008 | Sharp R-320H Microwave Oven
Sharp Insight Series : KB6002LS 1.0 cu. ft. Built-In Microwave Drawer - Stainless Steel Logo
26 people viewed this question
Top Sharp Kitchen Ranges Experts
William Miller
William Miller
Richard Lane
Gil Shultz
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
