Question about Olympus Camedia Stylus 300 Digital Camera
Won't take pictures.
My olympus digital camera will not take pictures. Normally when I slide the front open to expose the lens, it would telescope out and I could view the image on the screen on back of camera. But now, when I slide the front open, the lens doesn't telescope out and the camera does not come on. I can, however, turn the camera on to view previously taken pictures and the battery is completely charged, so that's not the problem.
    President:
  • 919 Answers
The problem you are describing is a problem with a sensor that is behind the lens cover door on the front of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 22, 2009
Telescoping lens opens but the view finder continues to flash an orange light and I can not push the button and take a picture. I have ordered a new battery to see if that helps because the camera is used...
Before trying the new battery, try cleaning the battery compartment contacts with a cotton swab dampened, not drenched, in rubbing alcohol. Blow dry the compartment and then try the new battery. Thanks, Dana
Jan 06, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
Camera part won't power on
I had the exact same issue with the D-395.
I wiped off the battery contacts and the ends of a newly charged set of batteries to make sure they were clean. Also while the batteries were out, I opened and closed the lens barrier or sliding cover to try and drain any juice still in the camera. I put the batteries back in and slowly/gently slid open the lens cover. It turned on and works fine now.
Nov 08, 2009 | Olympus Camedia D-395 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Camedia 5-60 pictures are black
Are you sure nothing is blocking the lens on the front? there is a slide that slides open and you can see the lens right? Is the camera in manual mode or auto? if its on manual flip it to auto to test. Point the lens at the light, does the display change? If you bang on the camera does it work? there are some connection problems with some sensors and they can flake out after a while and stop working. Sometimes banging the camera or twisting the case it will flicker or start working again. If it does the sensor is the problem. The screen could be cracked also. Do you have the tv cables with it? try to hook it to the tv and see if you get a picture.
Apr 06, 2006 | Olympus Camedia C-350 Digital Camera
Cover open, unable to take a picture?
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
Open cover
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cover open
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
177 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
