Question about Jamo Audio Players & Recorders
Connecting sw7000A subwoofer to a RX-a1000 amp
How to connect my jamo sub to amp RX-A1000 yamaha
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
  • 236 Answers
SOURCE: Yamaha dsp-A1000 5 ch Amp
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Posted on Aug 04, 2008
lynchms
  • 93 Answers
SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: bose speaker connection
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
Posted on Dec 28, 2009
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Posted on Mar 03, 2010
How do i connect ms 10 sub to yamaha RX-V1065 amp, I am using 2 monster cables.
The ms 10 is an active sub, so all you should do is connect the Subwoofer output on the rear of your amp to the LFE input on the sub with a simple audio cable.
Nov 27, 2011 | Mission MS10 Subwoofer
What port do i plug the subwoofer into
Look on the back: "Subwoofer Low Pass" for a powered subwoofer or amp driving a subwoofer. Your subwoofer's manual would suggest how to conenct it.
Jun 23, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Yamaha DSP-A1000 , wiring details
Go to Yamaha's web site and download the user manual. It's free!
May 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Jan 14, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
47 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
 Grubhead
Grubhead
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
