Question about Dacor EF24LBCSS 24" Beverage Center
Not defrosting Why is there ice build up on the inside of the beverage center
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
Ice build up
Sound as you have what it called a defrost problem.
There are 3 parts involved as defrost timer, limit switch or defrost heater.
May 27, 2014 | Beverage-Air BM23
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
MagicChef Beverage/Wine Cooler keeps getting ice build-up on inside back panel
Ice build up wil accor if the evaporater blower goes out and does not crculate the air. If you have the model number off the tag I can be of more assistance, with the mobel number I can break the unit componants down in a diagram
Oct 07, 2012 | Refrigerators
How do I fix a noisy fan blade. Can't figure out what it is hitting. The noise doesn't happen till fridge is on for few minutes.
oight be caused by build up of ice or unbalanced/worn fan, try defrosting it. if you still have problem have the fan checked out
Jun 02, 2011 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Cooler freezing up
The system is most likley working fine.
The problem is moisture in side the unit. It needs to be dry inside or ice will build up on the cooling unit. make sure the lid is fully closed also.
Feb 28, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Fridgadaire beverage center too warm
It should get cooler than that at least down to 33-34 degrees. Be sure you have air flow behind the unit, not pushed against wall. Feel for cold air coming from freezer to lower part just behind light bulb. If it is not turning off and defrosting they will do this as ice builds up and results in no air movement. you may want to remove the cover in the back of freezer and see if it is froze up. Or just turn it off and defrost and start back over the next day. The defroster timer may also be bad and it is under cover beside the light bulb.
Dec 26, 2008 | Frigidaire FRTB7B4EMB Top Freezer Beverage...
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Dacor EF24LBCSS 24" Beverage Center Logo
12 people viewed this question
Top Dacor Refrigerators Experts
Charles T Nevin
Charles T Nevin
Brian Coughlan
Are you a Dacor Refrigerator Expert? Answer questions, earn points and help others
