Question about Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook
Screen Flashing then Computer shuts down
Okay so i have this dell studio 17 laptop which boots up and everything but as soon at the dell logo pops up the screen starts to flicker and shortly after the computer shuts down. I don't think its the screen itself cause i plugged in a monitor via vga and it did the same thing. I'm not sure what else it could be. also the computer is running straight off the power cord and not the battery because the battery does not get recognized by the computer and when i plug in the cord i get 3 short blinks from the power light. is there any way i can get this back up and running? thanks
    Novelist:
  • 180 Answers
The two things I've dealt with in cases such as yours is I have sometimes failed to have a 110v outlet really, actually working. The other problem was when I wouldn't be patient enough to plug in the computer and let it charge for a while BEFORE attempting to start it.. I'm not knowledgeable enough to know for sure, but, in your case, I might also suspect a bad battery... that was sucking up too much charging juice... to allow the computer to start up and run.
Posted on Jan 04, 2014
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
Pyrhyc
  • 2028 Answers
SOURCE: flashing green and orange battery light on body of laptop
The flashing orange light indicates that the battery isn't working properly. This could be due to either the battery being worn out, or a battery fail safe has kicked in. Either way the battery will need to be replaced in order to fix this. Since the performance isn't quite right, I'm going to say that a fail safe has engaged, you can confirm this by running the computer without the battery and see how the performance is. You will need to replace the battery, and the replacement will make the machine work properly.
Posted on Aug 27, 2008
frcs68
  • 1605 Answers
SOURCE: Inspiron 1501 won't turn on
do you have the dell diagnostic CD??
if you have it may help you to figure what is wrong??
here is th link to the troubleshooting steps.
http://support.dell.com/support/edocs/systems/ins1501/en/om_en/html/trouble.htm#wp1062918
I suspect the hard drive may be on its way out. unfortunately you can't see the screen.
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: Dell Inspiron 1000 laptop LCD screen blackout
I HAVE POSTED THE SOLUTION FOR THIS BEFORE. ON THE LEFT REAR THE SCREW FROM BOTTOM OF UNIT TO THE LCD. LOOK INSIDE WHERE THE TOP AND BOTTOM GO TOGETHER YOU WILL SEE A PIECE OF ALUMINUM TAPE IF IT STICKS OUT PAST THE BOSS TOWARD THE PC BOARD. WHEN YOU MOVE LCD THERE IS ENOUGH FLEX FOR IT TO SHORT TO PC BOARD. TRIM THIS OFF AND YOUR PROBLEMS WILL BE SOLVED. CAUTION REMOVE BATTERY AND UNPLUG FROM AC BEFORE THE ABOVE. BOBBY
Posted on Jan 09, 2009
  • 3940 Answers
SOURCE: Dell Laptop Charger, wont charge bat. but keeps computer running.
The center of the connetor for the AC adapter to the system has a very fine wire that is the sensing wire for the battery charger. It ID's the type adapter connected to the system. If the wire is bent or broken, the system cannot ID the adapter and the battery charger will not function.
If the wire is bent or broken, then replace the AC adapter. ALso try a different adapter and see if the issue occurs with it. If the issue happens with more than one adapter or if this adapter functions normmaly on another system, then the motherboard will need to be replaced.
Posted on Jan 17, 2009
I have a Dell studio 17 slot load. Mechanism sounds like it is working but cd will not come out
Try this: Shut down computer using power button. Start again. Try to take disc out normally. Or go to My Computer-right click on dvd-eject.
Nov 17, 2010 | Dell Studio 17 Laptop
Dell Studio had boot problems. Analysis showed registry was damaged. Decided to repair Windows Vista. Put in Windows Vista DVD and began installation. At normal mid installation re-boot, laptop restarts...
Its better if you can reinstall the OS...
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If you dont find this default partition then go ahead and reinstall the OS and then install all the drivers for the system....
Sep 19, 2010 | Dell Studio 1737 Laptop
I have a question about my dell studio laptop 17in all it will do is boot to a blank screen an not sure what to do
sounds like something is wrong with the loading sequence. if u have the installer disks that came with the computer. u can run repair with the opperating system install disk. if that doesnt fix it try reinstalling the os .( you'll have to erase everything on the harddrive and will lose everything) and if that dont work then it is probably the harddrive itself and my need to b replaced
Jul 19, 2010 | Dell Studio 17 Notebook
Dell laptop w/ Vista - will post but then freeze up
Do you see the hard drive listed in the BIOS?
If not, probably a hard drive issue - but strange you can't boot from a CD.
Did you reset the BIOS to defaults? If it is a BIOS issue, you could try and flash it to a newer one (if it exists) but if it goes wrong you could brick your computer.
I had a failing hard drive in a laptop which would not boot up. I bought one of those converter things (laptop IDE to full IDE) so I could hook it up to my desktop pc as a slave. I was able to access all the data and transfer it to the new hard drive in the laptop. If you have a SATA connection on the laptop hard drive and your other computer then I don't think an adapter would be needed.
Mar 01, 2010 | Dell Studio 17 Laptop
Dell studio has dvd stuck in slot, i rebooted and the dell logo screen with status bar always stops 3/4 of the way through. And will not let the computer boot up, it just stays there frozen...please help
If your DVD is still struck in the drive. Insert 2 business cards half into the slot and feel for the DVD inside the drive. make sure on card is above the dvd and other other is below the dvd. Now press the eject option and bend the cards away from each other i.e. up and the other one down and pull the cards out of the slot. Your DVD should be out. Else repeat to get the Dvd out and try rebooting.
Dec 28, 2009 | Dell Studio 17 Laptop
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Dec 13, 2009 | Dell Inspiron XPS M140 Notebook
Factory setting on my studio dell computer
Boot up press Ctrl + F11 @Dell Logo screen and the Dell pc restore by symantec will pop up
any further help let me know
Nov 05, 2009 | Dell Computers & Internet
Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook Logo
61 people viewed this question
Alun Cox
