Question about Sam4s SAM5215 Er-5215M 1
This register appears to be ''closed''. Every mode states to be closed
I would like to learn how to reset if possible
  • 43 Answers
Closed means there is no clerk signed in. if either pressing the clerk button at the top right of keyboard or pressing 1 clerk does not sign in a clerk it has probably lost it's programming. to reset to factory condition turn the C key to six oclock position and unplug then reconnect plug while holding down the double zero button
Posted on Jan 17, 2014
Cannot get my 2009 colorado into program mode to set tps sensor
What engine ? Are you talking about Throttle Learn ? Did you replace throttle body ?
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
A vehicle that had a heavily coked throttle body that has been cleaned or replaced may take several drive cycles to learn out the coking. To accelerate the process, the scan tool has the ability to reset all learned values back to zero. A new ECM will also have values set to zero.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow.
Throttle Learn
With Scan Tool-Reset
Ignition ON, engine OFF. With a scan tool, perform the Idle Learn Reset in Module Setup.
Start the engine, monitor the TB Idle Airflow Compensation parameter. The TB Idle Airflow Compensation parameter value should equal 0 percent and the engine should be idling at a normal idle speed.
? If the engine is not idling normally, proceed with the Learn portion of the diagnostic.
Clear the DTCs and return to the diagnostic that referred you here.
May 16, 2017 | Cars & Trucks
I'd A Trade Name On Record, But It Doesn't Appear When Searching The Secretary Of State's Website. Why?
Only active trade names were moved in the Department of Revenue towards the Secretary of State's office. Closed, expired, or inactive trade title records weren't moved because those trade names are no more effective and can't be restored.
Oct 02, 2015 | Retail Supplies
Why does my service engine soon light stay on for at least 18 seconds after starting.
its possible the PCM has picked up an intermittent reading and set the light. you will have to check for a code before you clear it to reset the light.
Jul 14, 2015 | 2005 Chevrolet TrailBlazer LS
How to reset factory settings for a CASIO SES400?
this is work with me
the PGM key at Off press and hold down the Feed (journal) button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros, now press 23000 Subtotal (PCRT2100, 220S )
Wait for a receipt to print.
If resetting does not work this indicates issue is repair level.
Jul 11, 2015 | Casio Parts Cash Register PC Desktop
Reset TPMSS through cars menu
Most dealers will reset this at a there place of business,or try a tire store just ask what the cost is. Worst case is that the sensor in the tire is bad usually covered under car warranty,ask first.
Jul 17, 2014 | 2009 Honda Fit
My sam4s er-180t casg register now states its closed !! what doi do
Hi Clare,
I don't know if you have fixed the issue yet but I am going to respond anyways :). It appears you have accidently pulled yourself out of clerk mode by pressing "0" then "clerk". When you do this, you are telling the register that you have no cashier's using the register, so it will lock the cash drawer in place. To remove the close and continue ringing as an active register, you have to press the number "1" button, then the "clerk" button. This will allow you to use the register again. You can also assign multiple clerks so that you may pull individual reports if for some reason you have multiple people using the register. You just have to make sure when you do this that you hit "0", then "Clerk" first, then you can log in as Clerk 2, Clerk 3.....etc. etc. Clerk 1 will be your primary clerk and it's the clerk assigned when you first received the register.
I hope this helped. Sorry if I was a little late. I have been traveling and have not had the time to really sit down and write this out. If you have any other questions regarding this register model please let me know. I have kind of become an expert on them having used them for the last three years.
Good luck and hope this works for you.
Scott
Jun 22, 2014 | Sam4s ER-180T Cash Register
I have a 2013 ( I believe ) Buzz Lightyear Doll. I've found out my son has learned to remove the jet pack, where the batteries are stored. I found Buzz missing a battery, which I replaced, but he doesn't...
There is no reset button on this dolls he is broken unless you did not replace it with the same battery or possibly the dolls wire could have moved so it is malfunctioning.
Feb 22, 2018 | Toys
Garage Door Programme problem
If it does the same behavior with the Doorbell like button, it would be you closing force adjustment. They reverse when there is too much force to close (as when you left the trash can under it. Or the lorey was not all in)
Jan 13, 2014 | Coffee Makers & Espresso Machines
Sam4s cash register
turn the key to six oclock position, unplug and replug in while holding the double zero key. this resets register
Jan 03, 2014 | Retail Supplies
Sam4s SAM5215 Er-5215M 1 Logo
308 people viewed this question
Top Sam4s Retail Supplies Experts
Patrick Tinashe...
Andrew Taylor
Andrew Taylor
Electroboy
Electroboy
Are you a Sam4s Retail Supply Expert? Answer questions, earn points and help others
