Question about Nakamichi AV-1S Receiver
Tone button no longer works.
When the button is pushed it makes a crackling noise as if the connection is bad. Too cover off cannot see if tone switch connector has accessible solder connection. Any suggestions appreciated
    Problem Solver:
  • 17 Answers
How old is the receiver?
Does it crackle only when pushing the button or afterward in either position?
If it's getting old (10+ years) I'd suspect dirty contacts in the switch. If it's not completely sealed you can spray some contact cleaner in it and operated it repeatedly till it stops crackling. I found that what works best on switches and potentiometers is "Lube-A-Trol" heavy duty lubricant from Tech Spray. Even if the contacts aren't the problem that stuff will keep them that way longer. If the switch is completely sealed and there are no bad solder joints (sometimes the only way to be sure is to resolder them even if they look good), then I'd replace the switch.
Posted on Jan 07, 2014
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
May 06, 2011 | Panasonic 2.4GHz Digital Cordless...
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
If it's a distinct "tone" like 1000Hz, it's probably mis-programmed. Check www.mods.dk. You may find a manual there.
Mar 20, 2010 | Kenwood Radio Communications
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
One radio makes loud tone when other radio transmits
You may have a defective radio that has a bad push to talk switch which doesn't mute the receiver and feeds back audio to itself or this could be a bad solder connection or a broken wire inside.
Not much you can do except replace it or have a tech look at it.
May 11, 2009 | GE SmartHome (58173) 2-Way Radio
Phone button tone replaces dial tone
You first need to determine if it is THAT phone or the jack it is plugged into. I would swap the phone with another in th ehouse and see if the problem stays with the phone or stays with the jack. If its the phone take it back or trash it. If the problem is the jack and if you have "lines keeper service" the phone company will repair the jack for you. If you do not have the inside wire insurance, ask the phone company how much it will cost to repair. You may want to get a private technician that will fix it for you for much less. Good Luck
Dec 23, 2008 | Lands Phones
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
54 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
