Question about Conair Professional Ceramic Hair Straightener - Black
Can I get a replacement cord for babyliss pro TT, dog ate cord
Where can I get a spare spring for the arm of my curling Iron? I live in South Africa
no where unless from the manufacturer.they usually are made as a throw away item
Sep 01, 2016 | Conair BaByliss Pro Spring Curling Iron
My babyliss pro tt straightener hit the floor now it will not turn on
We live in a disposable society. In the old days, you could take small appliances to a repair shop and have them serviced. Today there are too many different devices from too many sources to adequately maintain and stock parts for any kind of repair shop. Also, most devices are so mass-produced that they would cost more to repair (labor cost) than the device is worth. unless the damage is obvious and can be repaired easily, you are best to just write it off and buy another.
Jul 14, 2016 | BaByliss Pro TT Tourmaline Flat Iron /...
Flat Iron is not heating up
There is no fuse. If you connected it to 220 which is common power in a lot of countries, then you ruined the heating element. time for a new iron.
Feb 21, 2014 | Conair BABINKW2091 White Babyliss Pro 1...
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
My dog chewed the cord to my Rowenta Iron
Yes, but not warranty covered.
Check your local yellow pages (yes, printed book) for an apliance repair shop (look for discount coupon in back while you are at it).
Does not have to be an "authorized" Rowenta shop ($20). Get an 8 foot cord if you think you need a longer cord.
The dog can be fixed, too: (I couldn't resist typing that) Wipe some "training spray (pet shop or WalMart $5)" (harmless to dog & environment) onto the new cord (NOT ON THE DOG) to train the dog to leave it alone.
Sep 21, 2009 | Rowenta DX6700 Iron
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Conair Professional Ceramic Hair Straightener - Black Logo
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
