Question about Vizio VW37L 37 in. LCD HDTV
No signal video
My dad was channel surfing this morning and he said all of the sudden the picture was gone ( replaced by an innocuous graphic of some sort. Whooshy lines over a green bkgrd) This is only with TV signal video: DVDs, VHS, etc. display fine. I think he must have accidentally hit some extra key that switched something off. But what? He was using the U-verse remote control ... not the TV's. Any ideas???
  • A. Cantu Jan 04, 2014
    Also, I forgot to mention that the audio comes through fine ... we've only lost video. AND only in a full screen mode: the PIP thumbnail which comes up when we select the channel guide works fine as does the system feature called "multiview". Thids displays a main selected channel w/ audio and then 3 other smaller sceens which toggle. The TV can display picture (and does in alternate situations) just not full screen. I am using an HDMI connection. The AV setting is RCA connecters and I even tried to connect it with a coaxial cable, just in case. But that doesn't work. I just may not have it set up correctly ( having never used it before).
3 Suggested Answers
  • 18 Answers
SOURCE: No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Posted on Apr 03, 2010
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
Picture is washed out and looks green. The TV is an lcd Flat 32" poloriod model. It is four years old. This just happened this week it's not been moved or anthing. It shows no change from channel to...
The tv Tuner board that recieving the incomming tv signal broscast is defective.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 06, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Tv suddenly shows no audio and no video for digital channles only yet all digital channles are detected durring the channel search
Sounds like you have a bad signal from the antenna or the cable. Unlike analog TV if the signal level drops below a certain level you loose the picture and sound completely. The fact that digital channels are detected during channel search does not mean they have a good signal. Try moving the antenna about.
Nov 29, 2009 | Olevia 237T 37 in. LCD TV
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
Video cuts out suddenly, have to reboot
Check to see if your video card is excessively hot. It sounds as if your video card is overheating and going into thermal protection.
A lot of times, when the GPU is damaged it will overheat as one of the final signs before it's impending death.
If this is the case I would replace it.
Feb 15, 2009 | ATI RADEON™ 7000, (64 MB) AGP Graphic Card
Don't have manual...don't know how to use some buttons
My guess on surf is it might scan channels for you. PIP is short for picture in picture and may require a second device with a seperate tuner. SWAP works with PIP button and switches (or swaps) between the pictures. FREEZE probably "freezes" picture until you push button again.
May 14, 2008 | Zenith MBR3447 Remote Control
I want to know how to use some features on my Zenith MBR3447 remote
My guess is SURF might let you scan through the channels like a scan button on a car radio. PIP stands for picture in picture and may require a second device(vcr etc.) with a seperate tuner to use. SWAP allows you to swap pictures when useing PIP. Freeze probably will allow you to freeze the current picture on the screen.
2005 phillips crt 27 inch tv
need electrolytic capacitor replaced in vertical circuit
May 07, 2008 | Televison & Video
Vizio VW37L 37 in. LCD HDTV Logo
60 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
