Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
Had company....set was working fine...when I returned, the set reads "failed to receive broadcast" [E202] 37" Sharp Aquos....1 yr old...
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
Posted on May 22, 2009
Sharp aquos instructions
That means the channel is active but but there is a problem with the delivery by the broadcaster, not a defective TV.
Dec 28, 2013 | Televison & Video
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Comcast tv failed receive broadcast e202
Check the input cable to the TIVO is is firmly connected at both ends?
Dec 16, 2013 | Tivo Televison & Video
Failed to received broadcast E202. what's wrong?
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp dtv e202 error was received
Try just changing the channel to the one set up to receive broadcasts. That worked for me-- the TV was working great until I pressed Input and for some reason that changed the channel away from channel 60, which is the one programmed to receive broadcasts from Dish Network. When I entered 60, the message went away and I got my programming back.
Nov 07, 2010 | Sharp Aqous LC-26D5U Television
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
2,501 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
