Question about Dell Precision Computers & Internet
Whistling noise - Precision Dell Computers & Internet
Whistle noise
A whistling noise can be generated by an alternator at high RPM's and indicates a slip ring brush problem or a diode failing . It resembles a frequency whistle.. IT may also be from a leaking gasket and a partially blocked exhaust system from a failed cat converter and at speed and power, the exhaust gas is forced out the hole
Dec 26, 2013 | 2012 Acura TL Base Sedan 3.5L V6 6-speed...
Whistling noise
There are many possibilities that can make vehicle whistling noise.
Click the link below and follow the details:
http://www.gresk.com/2013/09/car-make-whistling-noise.html
This will help.
Thanks.
Sep 22, 2013 | Peugeot Cars & Trucks
Whistling noise
I don't think your whistling is related to your chain adjustment. What else might be whistling ... helmet ... ???Did you change anything else? Was your chain loud before and possibly covered the noise you are now hearing?
Jul 21, 2013 | Honda Motorcycles
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Jul 13, 2009 | Televison & Video
Whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
Jun 23, 2009 | 2002 Acura 3.2TL
Whistle Noise
Check your air intake manifold hose if is crack this cause whistle noise replace the hose.
Feb 02, 2009 | 1996 Toyota Previa
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Computers & Internet Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
