Question about Norelco T770 Beard Trimmer
The plastic protection cover over the cutter is broken replacement required
Norelco trimmer t990 model , the plastic protection cover over the cutter is broken replacement required
    President:
  • 272 Answers
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
I bought some replacement cutters and holders for phlilips at890. the holders in my shaver hve two small lugs on each one,the replacement ones dont have these. wil this effect the shave
Model AT890 requires replacement heads with part number HQ8. If the blades you purchased are not HQ8, you have the incorrect parts. HQ8 blades can be found at shaveroutlet.com at the link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Oct 12, 2014 | Philips Aquatouch At890 Wet And Dry...
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Nov 08, 2010 | Norelco T 800 Beard Trimmer
Can I replace the trimmer blades (not the shaver heads) on my Philips 8175XL? I use them all the time and they are wearing out. Where do I get them and how do I install them?
You will find a replacement trimmer at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-sideburn-trimmer-p-388.html
See disassembly video tutorial at shaveroutlet.com using the link below. You will not have to disassemble as far as the video shows. Just remove the back cover and the trimmer can be 'disjointed' from the cover
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
Oct 27, 2010 | Philips Norelco 8175XL Electric Shaver
How many torx head screws to remove cover of 6863xl. Will trimmer need to be removed? Is so how?
On model 6863XL, there are just two screws near the bottom on the back. Remove the screws to remove the back cover. Trimmer will come off with the back cover
If you require parts, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=6863xl
Sep 23, 2010 | Norelco ReflexPlus 6863 XL Electric Shaver
Need spring that holds the head to the shaver and rubber cover that covers it.
On model 7775X the part you are asking about is not sold seperately. If yours has come off, it is because the plastic that holds it is broken. You will need to replace the head holder which includes this piece.
You will find it available at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-7700-series-cool-skin-head-holder-with-hinge.html
Apr 24, 2010 | Norelco Cool Skin 7775X Electric Shaver
How do you re-install the spring on the trimmer? This is for a Norelco 800RX shaver
The spring on the trimmer for model 800RX should not come out. If it has come out from the trimmer, almost certainly the two tiny bits of plastic that hold the spring to the trimmer are broken off. You will not be able to repair this properly...sorry
Apr 15, 2010 | Norelco Quadra 6828 XL Electric Shaver
Norelco shaver 800RX The spring on the pop-up trimmer came out while replacing batteries. Is there a drawing that shows how this spring is attached?The spring isn't broken, I need to know how the spring...
The spring has two coils, one at each end. They need to be pushed, hard, into the plastic tabs. I heard each side 'click' in. I wasn't pushing hard enough at first.
Aug 29, 2009 | Norelco Health & Beauty
Norelco 6735x trimmer head
Just pop up the top with the cutters. Next pull the cutters from the shaver in the back prongs. Insert the trimmer head and reverse operation when you are fiished. adrianjpater@usa.net
Feb 20, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco T770 Beard Trimmer Logo
381 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
