Question about Kenmore 24032\24036 Top Load Washer
Our machine does not always spin the clothes completely "damp"
It sometimes leaves the clothes very wet.
    Sergeant:
  • 187 Answers
Hi,  try these:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate my suggestion....
Posted on May 22, 2009
Atlantis MAV6260AWW is not spinning at full speed, its agitating while spinning leaving cloths very wet .
check under lip of washer or around outside of tub. A garment may be in the void between tub and basket. It won't always slow down spin cycle as it may roll around when spin cycle is on but occasionally it will ball up and jam between the basket and tub thus decreasing the spin speed. Socks are a common problem and if you are sometimes whiffing a foul water smell that is the article of wet clothing that has remained wet for some time.
Jan 12, 2015 | Maytag Washing Machines
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Spin cycle not completing
have you lost any garments in the wash lately? there may be one in your pump causing loss of power on the suction. When the machine spins out, have you noticed a marked decrease in time or just the dampness of the clothes? This is what leads me to believe this is a clog in the pump or the hoses to drains
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes after spin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Clothes still damp to wet after spin cycle
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. And rate me pl, if the solution has worked......
Dec 02, 2007 | Washing Machines
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washer spin cylcle leaves clothes wet
I Think you need a new drive belt. I'm having the same problem.
Oct 08, 2006 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 24032\24036 Top Load Washer Logo
164 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
