Question about FreeHand Systems Freehand MusicPad Pro Plus Version 40 Electronic Sheet Music Display
My MusicPad Pro Plus will not power up.
I just bought it, and I followed all the startup instructions. After plugging it in a letting it charge for two hours, I pressed and released the white button. The screen briefly flashed and flickered with the FreeHand logo and then the screen went blank. Upon subsequent pressing oif the button, sometimes it did nothing, and sometimes the first scenario is repeated.
Probably your battery packs won't hold a charge any more. See my post here
Posted on Nov 18, 2015
Whre do I Send my Freehan music pro to get repaired the battery wll not chrge.
I had BatteriesPlus make me new battery packs for my 2 MusicPads. Cost was about $100 for both, 3 years ago. Be sure you match the power rating (4500mAh) of your original component batteries. The ones they had in stock were only 3500, I believe -- which would give you less time between charges. They had to special-order the 4500's. Each of the two packs takes 3 cells, which they solder together. I just removed the old packs from my MP, BatteriesPlus checked them, found the replacement equivalents, and made 'em up for me.
Aug 25, 2014 | FreeHand Systems Freehand MusicPad Pro...
Load to default not working
Did you follow the instructions from the manual? If yes, at what point did this process fail?
Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..."
appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
I bought a Xenyx 1202fx roughly 9 months ago. I plugged it in following the instructions of desk to pack first, then pack to mains, but the LED display didn't show. I've heard that there's no...
If the blue power light does not light up then there is a problem with the unit or power supply. As it is less than a year from purchase I would advise returning it to the shop.
Sep 15, 2011 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I have a Focusrite Pro 10 i/o Firewire Interface and am experiencing 60 Hz hum through the mic pres when phantom power is switched on with the power supply attached. Phantom power running from 6-pin...
I assume you are using condenser mics as you would NOT be using phantom power with any other type connected or other devices plugged in while you have phantom power. It is important to have ALL interconnected equipment, including the computer, powered from the SAME receptacle or power source. Make sure the power supply you are using is SPECIFICALLY for the unit from Focusrite as some supplies have filtering within the wall transformer module and others do not. The power supply MAY be generating magnetic fields... try moving it around and see if hum is affected. The capcitive coupling in a power supply can let in higher frequency components from lamp dimmers. Make sure you have no lamp dimmers anywhere near the equipment.
Apr 25, 2011 | Focusrite Saffire Pro 26I/O 26 In/26 Out...
Hi my behrinher DJX 700 - damaged transformer i think, i bought the unit in canada and i used it with a voltage converter, worked just fine, recently my son pluged it in the uk socket and it bloone the...
Sounds expensive. How did the Canadian plug fit a UK socket? The fuse won't have blown fast enough to avoid all damage. Their coucld be an internal fuse - see instruction book. It won't be a home repair job it its not the internal fuse - sorry.
Feb 14, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
N12 and new Mac book pro with FireWire800
As long as you power the devices from the same receptacle or plug strip the MAC will be perfectely safe. Firewire and USB are fairly safe as long as you don't drive high voltage into them from failed equipment or ground loops.
May 07, 2010 | Music
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
FreeHand Systems Freehand MusicPad Pro Plus Version 40 Electronic Sheet Music Display Logo
46 people viewed this question
Top FreeHand Systems Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a FreeHand Systems Music Expert? Answer questions, earn points and help others
