Question about Sharp 40" Class 1080p 60Hz Slim LED HDTV - Black LC-40LE431U
Sharp model LG-40LE431U, bought 13 mo's ago, warrenty is out, lost 3/4 total volume, vet hearing problems, anyone else feel screwed by sharp! need help to fix!
Can't explain any further, loosing your TV's sound by 75% volume, something is wrong. I've other people look at this TV, it is not the controls.
  • 208 Answers
SOURCE: Sharp Aquos LC-26D4U sound problem
This unit has a chronic problem with the insulator material used on the heat sink on the ic's on the AV Bd. The unit must be disassembled and the AV bd. removed. The insulation on especially IC 2502 breaks down and must be cleaned off of the bd. and the ic and new insulator part # PSPAZA663WJKZ must be ordered and used as the insulator pad. If you send me an email to missiontracetv@msn.com I can send you the copy of the Sharp technical bulletin LCDTV-194.
Posted on Feb 26, 2008
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
SOURCE: sharp aquos fault
Thanks to this forum, I was able to confidently contact Sharp and get my TV fixed.
My 32" LCD had the same problem (sound but no picture) and was out of warranty, however I phoned Sharp UK and suggested that it was a manufacturing defect rather than component failure and should be repaired free of charge - which they did!!
  • 16 Answers
SOURCE: Sharp TV Audio Problem
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Posted on Jan 28, 2009
GOOD NEWS - - According to the Sharp Technician I just spoke with a "Service Bulletin" went out to all their techs about the sound issue on these Sharp Aquos. I'm having the exact same sound probem and I'm in the process of having the technician come out at no charge so call the number given in Solution #6 and #9 (1-800-237-4277) and keep pressing #1 until you get a technician. Have your serial number ready and they will need your name, address and telephone #. They will then give you a case number and transfer you to dispatch (which closes at 5pm central). Thanks everyone for your help and posts - you made our day!!!
BTW - We also have the problem of the TV turning on and off by itself but the technician said they had not received a service bulletin about that yet.
Posted on Jul 07, 2009
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
NO HOT WATER
it has a hot water element that can burn out
have it checked by an electrician or technician
Sep 11, 2017 | LG LDF6810ST Stainless Steel Built-in...
I bought a Sharp's Micro Component System some 5 years ago (27/11/05), it has remained in the box as new and I have just recently started using it. Within the last 3 months it has been played about 4 times...
I have bought things intended for future use but have never left anything in the box untested. With the speed of assembly and manufacture, junk gets shipped by every company so one needs to know early if an item is DOA or not.
I don't think you have any recourse but to have it repaired at your cost or add it to the huge pike of other dead Asian electronics.
May 29, 2010 | Sharp Audio Players & Recorders
I lost the volume in my earpiece on my LG EnV3... I can't hear anyone but they can hear me.. I have to open it and speak on the speaker phone.. is there a setting that I can change to turn in back on?
I just started having this same problem end of last week. It would work after I started the conversation, to close the phone again, but now that doesn't work either:( Someone please help!!
Feb 11, 2010 | LG enV3 VX9200 Cell Phone
No sounds
First i think you should call technical support , but their lazy asses will only say go to the store. It is probably the speakers so you might have to get some work done so it will work
Apr 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Dec 12, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp 40" Class 1080p 60Hz Slim LED HDTV - Black LC-40LE431U Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
