Question about Building Materials
Merlin 230t My garage door opens a couple of inches an stops. When I hit the bottom again it just closes. It won't go all the way up
4 Suggested Answers
  • 3197 Answers
SOURCE: Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Posted on Jun 15, 2010
  • 244 Answers
SOURCE: My merlin 230T won't open or closes with remotes
Unlock the LOCK
Posted on Jul 11, 2010
SOURCE: I have a Merlin 230T garage door opener which
There is a fuse in a Model M-230T and I have seen a service man change it.Now that the fuse has blown again, I want to change it myself BUT can't now find it!
Can anyone please offer a guide to changing the fuse?
Posted on Sep 30, 2012
Hey I want to know where the learn button is on merlin 230t garage door motor thanks
Press and release the green operate button to move the
door up or down. Press again to stop in the required fully
open or fully closed positions. Each time the operate button is pressed the door will stop or move in the opposite
direction.fio7c8ndqjcnbwivaodrak7uj3hwweu20kudaeajwikaaaadgbmbaaagacccaaamae4eaaayajwiaaawadgraabgahaiaadaaobeaacaaccjaaaaa4ataqaabganagaadabobaaagaa78f8dc5tazpfvnuuaaaaasuvork5cyiia
Feb 11, 2017 | Building Materials
The light stays on
guessing it is a sensor issue. the safety sensors
Aug 23, 2015 | Building Materials
Merlin prolift 230T won't open with remote. The chain goes around but it does not open or close the door
someone unlatched it to open by hand and the disconnect needs to click back in . give it a wiggle (the rope)
May 08, 2015 | Building Materials
I have a Merlin 230T garage door opener and it has started to run in the opposite direction. ie; it is closed now and when I use the remote control it tries to close more
Pull the emergency release handle. Use remote to open door then close it again with the remote. Now re engage the emergency release. That should put the chain in the right position for proper operation.
Aug 28, 2014 | Building Materials
Merlin 230t Door completes closing and goes straight back up again without using the remote...all adjustments have been made by a licenced door mechanic and yet it still refuses to stay down
Check for black marks on the wall or something it may be hitting . (if so the track is to tight to the wall)..... also Release the door from the opener and check it manually make sure its smooth and balanced correctly two panels up two panels down
May 26, 2014 | Building Materials
Merlin 230t
If the chain is loose I would definitely tighten it up to remove the sloppiness of the drive. That will in turn help you to accurately find the sweet spot that is currently eluding you. And you have to work fast because you do not want to overheat the motor.
Sep 21, 2017 | Sears Craftsman LiftMaster Chamberlain...
The garage door will open and then close then open and then the light starts to flash it's a Merlin 230t
This just happened to me. The issue was that the chain that the motor moves back and forth to open/close the door needed to be tightened as the tension had become slack, so the door was hitting the ground hard when it closed and the system automatically raised the door. I closed the door by adjusting the downward travel and then tightened the chain tension by twisting the bit at the of the chain (you'll see it and can use your fingers to do this), once done, then it was a matter of adjusting the upward and downward travel knobs and testing the door to make sure the door was back to normal.
Jul 27, 2012 | Home Security
I have a Merlin 230T garage door opener which abruptly stopped working altogether. Could it be the fuse?--or any other suggestions.
Sep 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
107 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
