Question about Miele Inspira G2140 Dishwasher
Dishwasher stops mid cycle, all lights flashing, but water fills, drains, and circulates
We have a Miele Inspira G2120 that's had light use (once a week) for 6 years. Getting the rinse, dry, end lights error about 10 to 15 minutes into cycle (have tried multiple programs). Dishwasher fills and drains, and water seems to circulate, but then cycle just stops with the error. I took the dishwasher apart to get directly to the motor and circulation pump, and the impeller (?) seems to turn freely. Put the unit back together, and getting the same error. Any help is appreciated.
  • 641 Answers
SOURCE: dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 09, 2007
SOURCE: Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Posted on Sep 25, 2007
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
reverendrave
  • 24 Answers
SOURCE: circulation pump is stuck
Hello Stonegroup,
The impeller is located below the bottom filter trap. Remove the tray and at the twelve 'O' Clock position you will see a small opening. Inside there are the pump impellers. take the Hackenschlussel (Hook spanner/Miele tool) and insert it in the opening and turn. You should turn it a few times and be able to feel the impellers free up. Also, Make sure you run the dishwasher atleast once a monch to avoid the circulation pump getting stuck like this
Posted on Sep 17, 2009
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I have a Miele Incognito G843 SCVi Plus. In a wash mode, the cycle stops in the first serveral minutes before soap is dispensed and the Drain/Intake light flashes. In Rinse and Hold mode the unit makes...
Hi
First check if the drain hose is not clogged and try to clean it as it can be that the hose is clogged and the water is not draining properly. After that check if the drain pump filter is fine and not clogged, try to clean that as well. After this check the metal filter, impeller cover and the air gap unit. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Dec 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Inspira Series Model G2140 U All program cycle indicators are on. I unplugged the dishwasher for 60 secs. and tried a hot/pans cycle and all the lights returned. What can I do? Thanks, Leo
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Feb 27, 2010 | Miele Inspira G2140 Dishwasher
Once the cycle is complete (rinse, drying, end) the dishes are clean but not dry.
#1 plastic dishes cups etc will rarely completely dry
check your heater, check for continuity on the heater it should ohm out.
does the heater get hot?
are you running hot water at the sink before pushing the start button?
are you using a rinse agent such as jet dry?
Sep 03, 2009 | Miele G892SC SS Dishwasher
Dishwashers Logo
121 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
