Question about Amana Refrigerators
My Amana ABB1924DES refrigerator stopped cooling. The compressor made an intermittent whining sound, like it was stuck. On advise from a repair technician I replaced the compressor start-up relay an
ABB1924DES bottom freezer. New control board, recently replaced damper control & thermistor(last year). If compressor is bad, should I replace it or buy a new fridge? Thanks Joe
  • Joe Pothier
    Joe Pothier Jan 05, 2014
    A service test shows that the defrost thermostat is shorted. Would replacing the thermostat resolve the warming issue?
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Posted on Dec 20, 2009
I have an amana abb1924des. A few days ago it stopped cooling. It was making click and buzzing sound. I changed the overload relay and capacitor. The refrigerator started working again for a few hours. The...
Hi there
Only bad news I'm afraid, the click and buzzing sound is a seized compressor, you said changed the relay and capacitor, good idea but often a seized compressor will come free if it cools for a while, unfortunately it will normally seize again fairly quickly. A job for the tech guy.
Best wishes
Gordon
Apr 17, 2011 | Refrigerators
I hava an Amana ABB2224DES bottom freezer refrigerator that is just 6 months past the warranty (it figures) and the freezer section stopped working. The refrigerator section seems to be working fine. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Amana ABB2224DES Stainless Steel Bottom...
Freezer doesnt freeze and refrig part only gets cool no matter how cool the temp is set. it made a whining sound for a day or two then quit on me
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 01, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator set at max and won't get cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jul 27, 2010 | Amana ABB1924DES Stainless Steel Bottom...
Refrigerator set at max but won't get cold
heatman101
Jul 26, 2010 | Amana ABB1924DES Stainless Steel Bottom...
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
6 yr old Amana has stopped cooling- light is on!
To make sure there is no damage to the compressor I want you to unplug the refrigerator. I will instruct you on what to test or advise you on how the repair should take place. If this is what you want, let me know. The problem could be something simple but to do these test answer me about this solution. Thanks, Sea Breeze
Jun 30, 2009 | Amana ABB1927DE Bottom Freezer...
Bottom freezer works fine....upper refrigerator has stopped working...
Hard to say with this description of the problem but sounds like your having a problem with the compressor starting consistantly. If it is a tecumpseh compressor it is most likely a problem. Take the back off the refrigerator and there will be sticker on the compressor that will tell what kind it is. Should say either embraco(the good kind) or will have a blue picture of an indian head (tecumpseh).
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
