Question about LG Heating & Cooling
Lg lw1810hr is blowing cold air in heat mode
The heating is not working on my unit. It was working fine, shut it off till next morning and now it only blows cold air. Everything else is working fine. Fresh air vent is closed, and I have unplugged for 60 seconds and plugged back up to re-set. What else can I do? Could it be a fuse or something needing replaced?
    Problem Solver:
  • 5 Answers
I assume this unit is a heat pump. It's probably the board.
Posted on Jan 04, 2014
Testimonial: "no not heat pump, window heat and cool unit."
  • hilary slaten
    hilary slaten Jan 04, 2014
    sorry, its a window unit with airconditioning and heat.
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
  • 56 Answers
SOURCE: Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Posted on Feb 16, 2009
SOURCE: LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Posted on Sep 13, 2009
koolbreezes
  • 540 Answers
SOURCE: heating unit is blowing cold air...
HEY< this sounds like an electric furnace and some heating elements are not working! WHY! Just call 918-6878813 and see if KOOL BREEZES cAN HELP!
Posted on Dec 14, 2009
SOURCE: My LG Lan125HV works fine on air conditioning (
I talked to LG customer support (800) 243-0000. The tech told me that this model had a problem with the indoor thermistor. It doesn't fail with an open-circuit condition, so you don't get an error code. The thermister just goes out of range and believes your indoor temp is much hotter than it is. That's why the heating never comes on. I'll bet that, even though it ran in COOLING mode, once your room reached setpoint, it just kept on cooling & cooling ... because the thermistor was still giving a false, high temp reading.
So, I bought a new thermistor, P/N 6323A20042A. My unit worked fine. Until the next week when I turned heating back on and now I have the same problem ... gives cooling but no heat. Something is failing the indoor thermistor OR the distributor sent me an old-style thermistor, I haven't gotten determination on that yet.
Regardless, call LG and see if they can't direct you to a distributor for an indoor sensor. LG's warranty coverage for parts is a royal pain, unless you can show a receipt by a certified installer, you're not going to have much luck getting payment for the part. However, the thermistor is only $10. Just hope you get one that doesn't fail on you!
Posted on Nov 27, 2010
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
LG lw1810hr window unit heat not working
Check to see if there's power to the reversing valve, if there is, try tapping it slightly with something kind of soft. You should give the reversing valve solenoid a continuity check with an ohmmeter to see if it's open or shorted.
Dec 07, 2013 | LG Heat cool Window Air Conditioner
Model lw1810hr - heat function blows cold air. Does not seem to get warm with temp set to max.
Check your heating sensor and also heating element. If it's reversible valve type, check the power to RV.
Dec 14, 2010 | LG Heating & Cooling
My LG Lan125HV works fine on air conditioning ( cool) but heat pump does not trigger when I move to heat or combined settings. Tried all temperature and fan settings, tried waiting to see if unit waiting...
Oct 22, 2010 | LG Heat cool Window Air Conditioner
Feb 15, 2009 | Ruud UBHC Air Conditioner
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Heater blows cold air
the electric motor that open the heat door looses electrical connection there by the door stays on cold / it is located under the a/c heater assembly / which requires removing the whole dash and heater assy// also bleed all air out of coolant system
there are three doors / 1/ a/c heat 2/ mode /defors 3/ recurculation dodgeboy6069@yahoo.com
Jul 19, 2008 | 2004 Jeep Wrangler
Heating & Cooling Logo
153 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
