Question about Invacare Pronto M51 Power Wheelchair
Battery lights scroll left to right chair doesn't move
Battery is fully charged, wheels are fully engaged/
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: the orange idicator light is flashing.
Replace the batters and used the correct battery charger, Not a car charger.
Posted on Sep 02, 2009
  • 103 Answers
SOURCE: DOESNT MOVE CHARGED WHEN TURN ON ALL LIGHTS COME
The motors are not getting power. Check to see that the chair is not in freewheel mode. Also check all the wires to be sure that they are connected properly.
Posted on Nov 16, 2009
bia1
  • 39 Answers
SOURCE: when should i charge batteries, should i plug in
No.. dont do that.. as that might weaken up your battery and ruin its battery life.. Only charge it when your using it!
Posted on May 23, 2010
SOURCE: the charge indicator lights flash left to
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Posted on Jun 16, 2010
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Battery fully charged chair levers engaged to drive position chair still will not move.. LIGHTS COME ON FLASHING
more info needed, what chair and what controller? is it all lights or just some and if so how many? are there two sets of lights (one for battery one for speed)? with out this info can not help.
I will have a guess and provide the error info for the most common possibility 10 lights flashing "An excessive voltage has been applied to the controller. This is usual
caused by a poor battery connection. Check the battery connections."
If this helps please click the "YES" button to let others know it is helpful.
Sep 27, 2014 | Health & Beauty
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
Where it shows the charge of the battery it keeps running across the screen and you can't use the wheelchair. It won't move. It does this every time after taking it off the charge.
Spot does the lights scroll from left to right or right to left? If they move from right to left then shuts down completely then the chair is in lockout or sleep mode. To unlock - turn the chair on and immediately press the horn button twice ( beep beep) This should get it out of sleep mode. Now if the lights are scrolling left to right then the chair still thinks it is being charged and the inhibit function is bad. You can call your local provider to have a tech check it or you can call Repair Xpress at 1-877-581-3733 to check it they have atech in your area to check it. Hope this helps
Aug 29, 2010 | Invacare Supply Group Invacare Pronto M51...
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Invacare Pronto M51 Power Wheelchair Logo
23 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
