Question about Whirlpool Refrigerators
Spoiled milk smell
It smells like spoiled milk cleaned tray underneath it was dry took everthing out couldnt find anything wat should i do
  • 41 Answers
SOURCE: spoiled meat thawed in freezer,
thats a terible smell too if its a frost free you may have to take the inside panels apart and clean behind it also on the self defrost mod.their is a drain pan under or in the back that would have filled with nasty juices dan
Posted on Jul 16, 2008
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Posted on Oct 13, 2008
  • 400 Answers
SOURCE: weird smell from refrigerator
Is the smell from inside the refrigerator or on the outside? If outside, it is possible a humid smell from the condensate drainpan water evaporating. You could put a very small amount (a couple of granules) of pool chlorine in the drainpan.
Posted on Mar 05, 2009
heavyt15
  • 91 Answers
SOURCE: My fridge smells terrible and I've clean out
You got some thing in the insulation...its done
Posted on Aug 19, 2009
  • 10865 Answers
SOURCE: Milk which was spilled in the fridge has dripped
Hello. yes. The tray can be slid out. Before you do this, unplug your fridge. Then remove the lower front grill, it just lifts off. Grasp the tray and gently pull it forward. J.
Posted on Jun 22, 2010
How can I clean under a car seat that milk was spilled on?
You might want to try a detailing shop. They have commercial products for just such a problem.
If the spill was in the fabric where a person would sit, it is in the foam padding too. And could have run down into the seams.
Nature's Miracle which is available at pet stores, or lemon juice and water will help cut the smell that remains.
Jul 25, 2013 | 2009 Hyundai Sonata
I have a Haier HRD-211 HP5 direct cool fridge. Last couple of days the air around the fridge is smelling like spoiled or sour milk - no smell inside or on the body of the refrigerator and cooling is fine...
Check the defrost water evaporator tray located inside the bottom grille. You probably will find a disgusting mess. Remove the tray and scrub it clean to resolve the problem. While you are cleaning up, check the tube that directs defrost water into the tray. It may be clogged.
Jul 02, 2017 | Haier Refrigerators
A carton of milk spilled in the refrigerator draining into the evaporator pan which cannot be accessed. any suggestions to eliminate the sour milk smell
take unit outside........ flush drain evap pan out with warm water and clorine bleach..hope you get all dry residue out......or take it apart and wash out evap pan...can you get to it from underneath???? easier.
if you do not remove milk residue you kitchen will smell forever...remember baby smells????
Feb 19, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
Smell under the unit, kenmore elite model number 44703
Hi: Not knowing your model number I would look where the milk was spilled and see if there is a hole. Possibly behind a panel for the defrost water. If so pour a little clorox bleach ane water in it. If not look for any cracks in the liner of your fridge. Those will expose the foam insulation to absorb the milk and cause odors. Clean them and seal them with teflon tape or a repair kit from the manufacture. On the off chanch the mild spilled to the front of the fridge and leaked behing the front grill the coils there are quite warm and will spoil milk fast. Pull the grill off and clean. I hope this helps, Jeff
Jul 07, 2009 | Refrigerators
Our Kenmore Coldspot has an awful odor whenever you open the door
use straight bleach on it. sponge down the whole inside with bleach and if you can leave the doors open on it to let it breathe and clear the odor out. bleach kills most smells if left on for awhile.go over it a couple of times if you have to to get rid of the smell.
Jan 17, 2009 | Kenmore Refrigerators
Smells like mildew. How do I clean it?
Affresh is a washer cleaner ..http://www.affresh.com/ made by whirlpool to clean out the washers...give it a try it really works
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Smell coming from it
I had the same issue and turned out milk had clogged the back drain plug so I had to take the back off and clean out the tube. Took a few trys and the smell was gone. Now having trouble with ice build up and leaking but this seems unrelated based on other complaints about this fridge
Jul 25, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
GE PDS20MBS
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Mar 05, 2008 | GE PDS20MBS Bottom Freezer Refrigerator
Refrigerators Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
