Question about Ariens Garden
Snowblower won't start - Ariens Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
When was the last time it ran? If this is the first run of the season then my guess is that last years 10% Ethanol Gas gummed up the carburetor. Need to take the Bowl off the carburetor and clean the Jet. Do not touch any adjustment screws just clean the bowl and the Jet, make sure the float is moving and put it back together. Then write your congressman and tell him to get rid of 10% ethanol gas. It does nothing to help the environment it only kills carburetors on all engines
Posted on Jan 05, 2014
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower won t start. pull cord too tight
How long has it setup? Could be varnished up, maybe broken ring, damaged needle bearings. Remove muffler an try to spray some cleaner or fuel in port to free it.
Mar 13, 2014 | Garden
Craftsman snowblower chute won t turn. the cables just spin inside the gear that rotates the chute left and right.
take chute apart where it pivots
theres a square hole that is now rounded
get some hard plastic 2 part glue from auto parts store
warm it all up build up sides flat again. or buy all new parts
my way is $7 or less and yes ive done this
Feb 03, 2014 | Craftsman 28 In 277cc* Dual-Stage...
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Garden Logo
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
