Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag fridge not cooling, freezer ok.
I have a Maytag side by side model MSD2756DEW that was not cooling properly, similar to problems as others are having. I called a repairman and he came over and replaced the advance defrost circuit board. This happened one other time also so it was no surprise. He advised to leave fridge unplugged for 24 hours to let ice melt then turn back on. Here is where the problem is. When I plugged it back in, it started for about 5 seconds and shut down. now, when I plug it in, it wants to run, but still shuts down after about 2 seconds. I replaced the run capacitor thinking that this would solve it, but it did not. I replaced the relay overload kit and that did not do it. There was one other relay that was in a clear shell so you could see the coil and the contacts. I am not sure what it does, but I decided it could not hurt to replace that also. it still does not work. The symptoms are the same. Compressor acts like it wants to start for a very brief time then shuts down. I am scratching my head on this one. By the way, after repeated calls to my repairman, he has not returned my calls. He does work for my employer and is a good guy. We have not seen him around lately either. I hope he is ok! I really need my fridge. It's been 2 weeks now. Anybody got some ideas? All are appreciated!
  • 87 Answers
SOURCE: fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Posted on Sep 06, 2007
fridgetech
  • 473 Answers
SOURCE: Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Posted on Nov 16, 2007
  • 148 Answers
SOURCE: Only lights and water dispenser are working on Maytag MSD2756DEW
overload switch for sure,stops the fridge once you replace that,if it doesnt defrost change the bi-metal
Posted on Jul 13, 2008
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
  • 2128 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
Jul 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Freezer is ok but fridgewont cool model msd2561kes done7at2four@sbcglobal.net
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Freezer is cold but fridge is not
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
tygf
May 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
215 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
