Question about Danby DKC645BLS Compact Beverage Cooler
Temperature controller issue
I was given a Danby kegerator, model # DKC645BLS, but the temp controller seems to be on the fritz. It initially goes back and forth between degrees C and degrees F and beeps each time, initially about every 10 seconds. And adjustments are hit and miss at best before it changes over to C or F again, steadily more quickly, and then finally it just errors out with a continual beep and has to be unplugged.
3 Suggested Answers
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
cobbslegion9
  • 3 Answers
SOURCE: Temperature controller malfunction
the adjustment dial , they are usually dirty from accumulated dust . at any auto parts store you can purchase a can of electrasol , unplug unit , spray into the middle of the switch, as you turn the switch, rapidly all the way around in both directions , repete this .. 2--3 times . look if possible, at the connections on the back of switch are clean ,and have good contact ... let device dry completely before plugging it back in and turning unit on.. let me know , good luck StevenT...
Posted on Jan 04, 2014
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Jan 04, 2014 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
15 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
