Imperial problems the jack shaft has worn an oval hole in the frame and causes the drive gear to not fully engage the axle geat and it loses traction etc. There is no bearing there other than the gear bearing on the jack shaft which seem worn but not real bad. I am tempted to weld the jack shaft tight in the oval hole it has worn in the frame but I am afraid that the gear bearing may be affected since it is so close. any thoughts?
  • 1861 Answers
SOURCE: right side axle shaft support bearing removal
Change the whole axle. You will waste TONS of time trying to change that bearing, and it is virtually impossible for a guy to do it without a real good machine shop. Trust me. Change the whole axle.
Posted on Sep 12, 2008
  • 5 Answers
SOURCE: front axle - front drive shaft Toyota tacoma 1998 4x4
more than like have a broken axle shaft, un hook the rear drive shaft and put it in 4wd if it wont move then you know you got a broken axle shaft or spider gears broke in the pumpkin
Posted on Dec 09, 2008
DJ_MAX1369
  • 119 Answers
SOURCE: 97 fatboy starter engages but will not stay engaged.
I would check the starter clutch its self first. It is a one way clutch so if you remove the starter and disassemble it to the starter clutch and hold the starter clutch in one hand and use your other hand to turn the starter clutch gear, it should only turn in one direction.
Posted on Mar 31, 2009
gladys_neal
  • 334 Answers
SOURCE: I have a 2001 Chevy 2500 4X4. Four wheel drive not
Sounds like the chain in the transfer case has broke or the linkage is out of adjustment
Posted on Dec 08, 2009
SOURCE: 4 wheel drive wont engage on kia sportage 2001
there are vacum line one on each side behide the wheels see if they are broke or leaking i had the same problem
Posted on Mar 22, 2010
Norma, 10hp, 29" snowblower, forward gears not working, reverse gears work fine, any suggestions
if its a NOMA THEN ITS AN OLDER MACHINE
check the bearings on axle shaft
worn bearings cause friction drive wheel to lose contact with drive plate
Feb 19, 2015 | Cars & Trucks
Why does my 1993 Jeep Cherokee 4WD wobble real bad when I hit a bump going 55 mph?
Ball joints, tie rod ends, pitman arm end, cracked suspension or front frame, loose steering gear, rotated axle housing, bad shock absorbers, unbalanced drive shaft, bad universal joint, loose lug nuts, loose axle shaft nut, bad wheel bearings... go through it ALL, very carefully.
Jul 26, 2014 | Denso 1993 Jeep Cherokee Sport 4.0L...
4 speed automatic Transaxle
If it was moving prior to this repair then most likely the axle isn't fully engaged. This would make all the power go to that wheel and render the vehicle motionless. Make sure you got the right axle and that it engages into the final drive.
Apr 16, 2014 | Pontiac Sunfire Cars & Trucks
The starter wont stop running after car is started
Can be caused by a few different problems:
1) Ringgear/pinion gear worn, causing them to remain meshed
2) Starter axle shaft worn causing pinion to not retract
3) Electrical fault causing soledoid to remain engaged
First, disconnect main lead on rear of starter (large wire from battery to starter) and try the key, using the test lamp to confirm that the signal wire (small) is only live when the key is in the start position (when key springs back to on, it should go dead) If so, then problem 3 can be ruled out
Remove the starter motor from the engine and inspect the starter pinion gear, check for wear on the pinion gear, if it has scalloped enough to catch and not be able to retract, check ringgear on flywheel.
Inspect pinion axle shaft, depending on starter motor design, it may have multiple axles, the main place to check is where the pinion slides up to engage the ringgear, bad wear on that shaft can cause the pinion to become stuck engaged.
Last test is to fire up the starter out of the car, and see if the pinion fails to retract after the solenoid feed is stopped.
May 06, 2011 | 1994 Mercury Tracer
Troy-built 21" mower - self propel problem. From my research it seems like a manufacturer problem that was availiable thru a claim but I am the 2nd owner so I must fix myself. Its a model 834. I have...
do you have the complete model number from the data tag on the mower frame? there are two typical systems for these machines, both require the belt to be tight and not slipping at the crank shaft, and the pulley on the trans-axle to not be slipping on its shaft, the older style trans axle uses a belt tensioner system to tighten the belt and turn the pulley, i.e. if the pulley turns then the axle should too. this can be checked by hand with the axle and belt removed. the second system is a clutch style axle that has a constantly tight belt and uses a small cable controlled lever on the transmission housing to engage a drive clutch inside the transaxle, if moving the lever forward doesn't cause the axle to turn as the pulley and shaft are turning the clutch mechanism is usually toast. with both of these systems one should also note whether the axle is turning inside the wheels when they are on the ground, the over running clutch sprags inside the drive gears could be stuck causing the wheels to turn without resistance applied, but stall when in contact with the ground.
while inspecting the trans axle note any wobble or free play in the axles or input shaft, this will indicate a worn case or bearing, resulting in a slipping gear in the trans axle.
Jul 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 06, 2009 | Ariens Garden
How to remove a 2000 dodge ram rear end
Unhook your dive shaft from the rear end. Take your U bolts of off your springs. Make sure that you disconnect the break lines from the rear axle. remove your shocks. It should be free at this point. In stubborn cases, you may have to put a small jack in between the frame and axle and apply very light pressure. Hope this helps.
Oct 10, 2009 | 1998 Dodge Ram 1500 4WD
The engine loses power when 1st gear is engaged,
This sounds like a broken tooth on the main axle. This would account for the lump in every gear and a power loss due to the axle being bent also. I would change the axle, support bearings, and the gear the axle engages. Check the output shaft for bending also.
This could be bad bearings on the shafts but is is highly unlikely if the gearbox oil has been kept at proper levels. In any event, the gearbox will need to be opened up for inspection.
This image is generic and not specificly the TRX850
Aug 05, 2009 | 1997 Yamaha TRX 850
Rear axle leaking
Block the front tires. Break the rear lugs loose. Jack up the rear of the truck at the center if possible. remove the wheels & brake drums. Remove the brake shoes,return springs & all the other hardware. Remove the differential cover & drain oil. If you have a posi the next step sucks. You need to remove the threaded pin from the housing & remove the axle retaining clips. All the while,being carefull of the spring in the posi unit. If no posi,then same procedure,minus the "pucker factor". After the axle is out,take a large flat blade screw driver or pry bar & pop the seal out. Keep in mind the axle bearing is probably gone too , so that's another procedure. Keep it apart,you'll be glad you did.
Jun 23, 2009 | 2004 Ford F150
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
