Question about Kenmore 63942 Dryer
Push the button dryer wont start
Kenmore 97281100. Is there a fuse or switch to replace?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Check the door swich Vitally
Posted on May 22, 2009
Kenmore elite dryers made 2005 was in a foot of water in a flood. push the start button just clicks. push the start button and hold it down and the drum wont turn on but the ignitor will heat up and lite...
foot of water huh
well any relay switch fuse ect.
the top board should be fine.
is there any rust inside the housing if so the dryer is definitely not safe to use anymore.
check for wires with water in their conections.
Jul 29, 2010 | Kenmore Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Wont start
It depends on how old, but if it's less than about 12 years old, it is probably either a thermal fuse, or the door switch.
Feb 13, 2010 | Kenmore Dryers
Push start button wont start dryer
This could be the non resettable thermal fuse has popped, or the door switch is not working. Open the door and press on the door switch until it clicks and push start to see if it works. If it clicks and still no start, then the thermal fuse needs replaced. UNPLUG the dryer, remove the back and you will see the white thermal that looks like a regular thermostat with 2 wires on it. It is located on the air plenum. There could be 2 depending on the exact model, but normally only one white one. These thermals usually pop when the temperature gets too hot as a warning something needs checked. Check your vent and be sure it is absolutely clear, and the flapper on the outside is not stuck with lint buildup.
Nov 27, 2009 | Kenmore 62602 Electric Dryer
Dryer not hot
check to see if the thermal fuse has continuity. or the heater element might be bad.
Nov 01, 2009 | Kenmore Dryers
Dryer wont start.
Some start buttons do not click. But it sounds like maybe the door switch.
Sep 25, 2009 | Kenmore 659 Electric Dryer
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
Doesn't start
Try this link and see if this helps you diagnose your problem. Please don't hesitate to contact me if you require further assistance.
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope this helps you isolate your problem. Let me know if you need assistance in locating parts too.
May 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
212 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
