Question about Smoothfitness EVO FX25 Folding Soft-Drop Treadmill - by Smooth Fitness- 1 PIECE AVAILABLE
Smooth Fitness treadmill 5.25 buzzing noise
My Smooth Fitness 5.25 treadmill has a very loud buzzing noise. This happens when you first turn it on, before you start the belt moving. It sounds like it is coming from the main motor area. If I fold up the treadmill the noise completely goes away by about 45 degrees getting quieter the farther I go up. This is true even when the belt is running.
  • Steve Holm
    Steve Holm Jan 04, 2014
    OK, I fixed it. I opened up the case and on the right side of the circuit board is a transformer. That was shaking and rattling at a high frequency causing the loud buzzing. I removed it, put fabric under and reattached it. I used zip ties to hold the loose metal casing still with more padding and finally siliconed the loose metal in place. The treadmill is now completely silent except when actually turning the tread.
Treadmill incline won't go up
This can be caused from several things. Please elaborate on what happens when you try. Is there any error codes etc. Whats the model number?
Mar 02, 2014 | Smooth Fitness 7.1 HR Pro Power Folding...
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
Err 2 showing on smooth 9.35 treadmill
adjust the SPEED SENSOR, clean it, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are the motor need repair
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the b. diagram
God bless you
Nov 14, 2012 | Smoothfitness Smooth Fitness 9.35HR...
Smooth fitness treadmill beeps every two minutes
Walk on a treadmill to calculate distance.
Most electronic treadmills allow you to program for an alarm or beep when you've walked a certain distance.
Try to turn off reading your owner manual.
And check if there are some error code?.
If you do not have owner manual go to this web:
http://www.smoothfitness.com/support/product-manuals.htm
and download free.
sincerely.
Nov 22, 2011 | Exercise & Fitness
Oil can is showing. Where do I put oil? (otherwise, I love the thing).
I called Smooth Fitness and talked to the Service Tech. The oil can symbol is basically a reminder to oil the tracking or underneath treadmill matting. The symbol will go away, from that Service Tech told me. You can also purchase a Silicon Spray(PArt 8300) for a few dollars instead of buying Smooth Fitness's Silicon Oil for about $35.00+.
Mar 03, 2011 | Smoothfitness Smooth 5.45 Folding...
In the display to the right of the calories catagory, an Oil Can icon haas appeared. Can you explain the problem or what I should do. It's a 5.25 model.
Oh, our model is the 5.25.
Apr 18, 2010 | Smoothfitness Smooth 5.45 Folding...
My Life Fitness 9000 Treadmill is making a loud rattling noise when i use it which is getting louder. THe belt is fine and i cannot see any loose parts. It sounds like a grinding noise. There is a lot of...
Could be a number of reasons - where is the black dust coming from? remove the motor hood and check for misalignment of the drive belt from motor to the front roller.
Apr 06, 2010 | Life Fitness 9000 Next Generation...
Thumping noise that increases with speed
OPEN MOTOR SHROUD SO YOU CAN BETTER INSPECT THE UNIT CHECK THE DRIVE BELT THEN I WOULD CHECK THE RUNNING BELT TO SEE IF THEIR IS ANY DEBRIS THAT THE BELT ITSELF IS SPLITTING SINCE YOUR SAY A THUMPING SOUND. SINCE KEYS FITNESS MADE THIS UNIT THEY ARE NO LONGER IN BUSINESS, BUT TREADMILL DOCTOR HAD PURCHASED THE PARTS. SO GO TO TREADMILL DOCTOR.COM THEY MAY HAVE THE PARTS YOU NEED
Mar 01, 2010 | Smoothfitness Smooth 5.45 Folding...
3 yr old Smooth Fitness 7.1HR Pro won't Unfold
Did you unlock the lift control? You have to rotate the knob that is just above the pwer switch to let the unit lift or lower.
Feb 23, 2010 | Smoothfitness Smooth Fitness 7.6 HR Power...
Smoothfitness EVO FX25 Folding Soft-Drop Treadmill - by Smooth Fitness- 1 PIECE AVAILABLE Logo
46 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
