Question about Kenmore Dishwashers
Stripped screws attaching dishwasher door
The stainless door is now hanging on by a thread as multiple screws are stripped and no longer grip. The door has been taken apart many times and the problem is when attaching the stainless steel portion of the door back to the unit. Half of the screws no longer grip when loaded into the holes. I know with wood you can put a toothpick in the hole to provide material for a screw to grip. Is there some sort of apoxy or other material that could be used. The door assembly to this model is no longer available. We just replaced the float swtich so it had to be taken apart yet again.
  • 653 Answers
Go to the hardware store and buy the next larger sized screws.
Posted on Jan 03, 2014
Cerfer39
  • 709 Answers
SOURCE: Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Posted on Sep 26, 2007
  • 11 Answers
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
SOURCE: upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Posted on Feb 16, 2009
  • 212 Answers
SOURCE: Have roaches in the door of our dishwasher! I
throw away dish washer
Posted on Jun 20, 2009
Any ideas on how to remove a stripped screw from lawn mower, Briggs and Stratton, top plate, there are 3 screws and one is stripped not allowing the cover to come off
By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
Jul 08, 2017 | Briggs Garden
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
Stripped screws on dishwasher door
Take a couple of the screws to your local Ace Hardware store, or a Lowes, or a Home Depot, or a Menards, and explain your problem! They will fix you up with replacement screws that will grip.
May 11, 2017 | KitchenAid Dishwashers
Whirlpool adg7560/1 can't attach fitted door
The square bits should be inserted into the large opening of the keyhole slots and slid down into the narrow part. This probably has to be done as a single operation with all square bits aligned with the large openings before the strip is slid into place.
Nov 07, 2013 | Whirlpool ADG75601 Builtin Dishwasher
Dishwasher door removal/replace
Short of buying new hardware, that is what I would do. Make sure that the threads are not metric and also make sure that you use stainless steel
Aug 13, 2013 | GE Profile PDWT580RSS Fully Integrated...
Dishwasher leaking
This sounds like a hinge problem to start with.
Test the seal by dragging a strip of paper through it with door closed. Probably that left hinge isn't holding door close enough which was probably the original cause. As seal dries out a bit then will leak.
At this point I would investigate the hinge possibility AND if possible a DIY fix. It may be loose mounting screws or take a little shim to hold the left corner tighter. I would not waste money for a service call.
You probably might need to release the door balance springs accessable under the toe kick area while working on the door. Possibly a hinge is bent.
You might do as they do in the auto industry when a door doesn't fit... basically put forces on it to bend it a bit. In your case it would be to distribute the load and support the door when horizontal about 6 inches out from the left hinge and then bend the end of the door down to bend the hinge mounts slightly..
Then check the seal clearance with the strip of paper as you do with a refigerator seal by cloosing on a strip of paper and dragging the strip to see if it is gripped.
May 13, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Door
With the door in the open position, looking down at it, you'll see a number of screwheads along three sides (the non-hinge sides). By unscrewing all of those you'll be able to lift the inner stainless steel plate away from the rest of the door, exposing the wiring. NOTE: lift the inner plate away easily as wires are attached to it. ALSO: I suggest keeping track of which screw goes to which hole as 2 of them are longer than the others.
Aug 23, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
LOOSE DOOR HANDLE
Remove 4 screws(Torx 20) along both sides of inner door liner. Be sure to have a good grip on the outer door as it will fall off. I always start at the top of the door and work down. You may have 2 blocks fall off, they go on the hinge and fit on only 1 way with the slot on the hinge.
May 10, 2008 | Bosch 24 in. SHX36L05UC Stainless Steel...
Cannot attach tripod plate to scope - stripped receptacle
Hardware stores should have thumb screws in different sizes and thread lengths ... box stores , local hardware ....
Jun 11, 2017 | Minox MD 62 ED W 62213
Dishwashers Logo
116 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
