Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How do I add a user to scan - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
How to add a user to scan on the network
open the browser from your computer, type the ip address of the machine,the machine webpage is going to open. look under basic, address book, add contact, you can add users from there.
Dec 21, 2011 | Kyocera Office Equipment & Supplies
How do I scan using a ricoh afcio mp201?
Hello!
This is a very good machine.
You can use scan-to-folder or scan-to-email.
The first step is to add users in the address book.
You have many configurations to make so i will suggest you to take a look in the user manual.
You will see everything to help you (step-by-step).
See you!
Jun 22, 2011 | Ricoh Office Equipment & Supplies
I am trying to add users onto my gestetner all in one. I want to add user so they can have the ability to scan documents to their email account and remove the users that are no longer required. What is...
You can do it with the Web Image Monitor.
It is easier and faster.
Open the browser and type the IP address of the machine and login as:
user: admin
pw: (no password)
Go to address book and you will see the users there are created. You can add or remove depending on your needs.
Hope that helps.
See you
Apr 19, 2011 | Gestetner Copier
Hi we have just installed a gestetner asm645 (i think thats its name), and want to delete the old companies accounts as when we try to scan something it says it needs a "senders" account to scan...
can delete user accounts under system settings. Press the button marked 123(where you get your meter reading). under system settings go to administrator tools and address book managments. can delete user accounts and create new 1's. Or you can trun the user authentcation off. Then no code is needed.
Sender - under system settings go to file transfer. input your smtp and managers account email. When programing user in address book look for add as sender and input the email address. When emailing you can select sender and destination. If the user is not set up as a sender the list will be empty and you would not be able to select a sender. set up a user (email) that any one can use.
Jan 21, 2011 | Gestetner Copier
Adding user to scan to FTP bizhub C350
You ned to check the appropriate window based on the first letter of the button.
If you want in on the first screen, you need to indicate to add the button to your "favorites". Otherwise it appears under the alphbetical listing.
Feb 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do you add and delete users' emails for scanning
U can store all the users emails on address books. Then when u want to perform scan to email, just press the email button on the particular to add, re-press again to remove.
Jan 08, 2010 | Toshiba E-STUDIO 650 Copier
Currently working on XEROX WorkCentre Pro 55. Want to scan documents to my computer from newwork printer. What do I need to set up in order to utilize this feature. I tried scanning to a programed user...
> Support & Drivers > WorkCentre Pro 55 Support > Search Results Solution: Set up Network Scanning Using Server Message Block (SMB) Filing With CentreWare Network Scanning Software v 5.5x bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Prerequisites:
  • The printer must be connected to the network.
  • The IP Address of the printer is required, and the HTTP option must be enabled on the printer. If you do not know the IP Address, or whether HTTP is enabled, print a Configuration Report. See the Related Items below for additional information. If you do not have this information or the printer is not configured correctly, contact your System Administrator for assistance.
  • A user account for the scanner to login to the scan server must be created (account needs full control access rights). The user needs to be a local user on the workstation and not a domain user.
    NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
  • CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
  1. Click on [Start], point to [Programs], select [Xerox CentreWare], and then select [Add Network Scanner]. The Add Network Scanner Wizard window will be displayed.
  2. Click on the [Enable a new Xerox System Scanner for network scanning and associate it with a scan server] radio button, and then click [Next].
  3. Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
  4. If Specific IP Address is selected, an IP Address field will be displayed. Enter the IP Address of the printer in the field, click [Next], and then skip to step 7.
  5. If Specific TCP/IP Hostname is selected, a Hostname field will be displayed. Enter the printer’s TCP/IP hostname in the field, and then click [Next].
    NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
  6. If the printer has been configured for Scan to File, a window will be displayed with a 'This device has already been configured for network scanning. Continuing will overwrite its current configuration. Do you want to continue?' message. Click on [Yes].
  7. The Enter Password window will be displayed. Enter your system password in the field provided, and then click [OK]. The Server Type (Filing Protocol) window will be displayed.
    NOTE: The initial system password at machine install is 1111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  8. From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
  9. Click on the [Browse] button located below the Location (\\Server\ShareName\Path) field. The Choose Location – Windows (SMB) window will be displayed.
  10. Browse to the server and then to the Scan folder where the CentreWare scanning folders will be installed, and click [OK]. The Location field will be displayed with the scan server name and the path to the shared scan folder.
  11. Click [Next]. The Xerox System Login Name window will be displayed.
  12. Enter the scan user name and password (this is the user account the printer will use to login to the server share) in the fields provided, and then click [Next]. The Distribution Server window will be displayed.
  13. Do not make any changes. Click [Next].
  14. Click on [Manage User Templates]. The Manage User Templates window will be displayed.
  15. Click on [Modify Template List] to begin selecting template users for this scan server installation. The Modify Template List window will be displayed.
  16. Make a selection from the list of Users and Groups, and then click on [Add] to create a scan folder and template for the selected user or all members of a selected group. If necessary, repeat this step to add additional users or groups.
  17. When you have finished, click [OK] twice. The Finish window will be displayed.
  18. Click on [Finish] to upload the scan settings to the printer. The Add Network Scanner Wizard window will close when the settings have been uploaded.
Jun 02, 2008 | Xerox Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
