Question about Rocketfish RFWHP01 Wireless Headphones
Turn on rocketfish wireless headphones and Internet stops workingg
Rocketfish RF-HPL302 brand new. hooked up with everything off. first got great sound but video that was jerky &couldn't keep up. then just a green screen. now nothing even on the pass through hdmi
it seems like a component failure, I would send this back as dead on arrival. this can happen sometimes that shortly after switch on a component fails and the devices no longer works. you should follow up with your dealer under guarantee.
I hope this was useful.
Nov 16, 2014 | Rocketfish Audio Players & Recorders
Ricketfish srs wow - mic is not working
  • Press the PWR button on the wireless receiver to turn the unit on. The headset has a sleep/standby mode feature to preserve battery life. The unit goes into sleep mode if there's no input for 3 minutes.
  • Twist the tip of the microphone so the sound holes face your mouth.
  • Position the microphone several inches away from your mouth so it does not overload when you speak. Try to balance the microphone position and the volume setting for optimum voice level.
  • Press the ALL MUTE button (the Rocketfish logo) on the left side of the headset once to make sure that the All Mute function is not activated. The LED on the wireless receiver will light red when All Mute is activated.
  • Make sure that the volume on the wireless receiver is not turned down or muted. The LED on the wireless receiver will light orange when Mute is activated.
  • Rotate the CHAT VOLUME dial on the wireless receiver to control the chat volume.
  • Make sure the USB cable is connected to both the wireless transmitter and your device.
  • Make sure that all connections are correct and secure. Sometimes a cable may appear to be connected but it may not be pressed in all the way.
  • Make sure that the wireless receiver batteries are installed correctly. See Question 19.
  • Make sure that the wireless receiver batteries do not need replacing.
  • Make sure that the microphone isn't plugged into the Line In port (or vice versa).
  • Make sure the headphone jack is pushed all the way into the port.
  • If you're using an Xbox 360
    • Make sure the wireless receiver is connected to the Xbox 360 controller using the supplied chat cable. On the wireless receiver, press firmly, so no part of the silver jack is showing. This tight connection helps to make sure the cable does not fall out during gaming.
    • Try a different Xbox controller.
    • Try recording a message to a friend by selecting My Friends, Send a Message, then Add Voice. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
  • Try testing the microphone by connecting the headset to a smart phone and make a test call or record a memo. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
If these steps don't work, then I would advise seeking replacement.
Jan 21, 2013 | Rocketfish Srs Wow Wireless Gaming Headset...
Right head phone in op
It looks like you will need to open them up and look for a loose wire in both earpieces. Also, while there, check to see if the batteries are in correctly relating to polarity!
Jan 15, 2013 | Rocketfish Rf-rbwhp01 Wireless Headphones,...
How do I pair my RF-MAB2 to my Dell Latitude D620 Laptop?
Make sure your computer has a bluetooth radio (either internal/external). If it does, verify that you have the software to pair devices, such as Broadcom's software found here - http://www.broadcom.com/support/bluetooth/update.php
May 07, 2012 | Rocketfish Mobile Rf-mab2 High-definition...
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
SHIFT KEY DOES NOT FUNCTION ON ROCKETFISH WIRELESS KEYBOARD ANY SUGGESTIONS WOULD BE APPRECIATED
If you have another keyboard try using that and confirm if that works properly.
Incase you don't perform the below mentioned steps :
Click on start
Click on run
type CMD
test the shift keys on the black window.
If it does not work here it is a problem with the keyboard.
Jul 20, 2010 | Laser Rocketfish Wireless Multimedia...
Where can i find the passcode for my rocketfish bluetooth adapter
Try 0000
most devices have a default code.
this one seems pretty common.
You can reset your code in most cases. Read the manual.
don't forget to rate me!
Jan 10, 2010 | Rocketfish Bluetooth USB Adapter...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Rocketfish RFWHP01 Wireless Headphones Logo
23 people viewed this question
Top Rocketfish Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rocketfish Audio Player and Recorder Expert? Answer questions, earn points and help others
