Question about Generic Memory nVIDIA FX5500 256MB 8x PCI Dual Head Video Card Graphic Card
Irsetup.exe active cpu 99% and when shut down pc restart
Driver installed sucessfull but when i shut down the pc it will restart and in process manager irsetup.exe active with cpu usage 99% thanks.
  • 331 Answers
It should have deleted itself after you installed your driver.
The file IRSETUP.EXE is not adware. It is actually part of the extremely common Setup Factory 6.0 installer builder product by Indigo Rose Software (www.indigorose.com). It is extracted to a temp folder when running a setup.exe created by Setup Factory 6.0 and used to handle the main installation tasks. It is deleted at the end of the installation process or at the next system reboot at the latest.
Setup Factory 6.0 is used by *millions* of setup.exe's and many thousands of companies
Posted on May 24, 2009
  • Raymond Ramirez
    Raymond Ramirez May 24, 2009
    did you try to reinstall the driver. or if you downloaded it try and redownload and run as administrator. right click on it and run as administrator
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Hi friends i also have cq40-330tu laptop i install xp sucessfull but i install also audio driver in sucessfull but after restart audio driver it's gone some many times i face same problem how to slove this...
compag cq40 support only vista but you can install xp but some driver be not support.
but i can help setup all driver please add my yahoo i will help you do that. My yahoo: nghiemlaptop@yahoo.com
Jan 19, 2010 | Computers & Internet
I have D101GGC motherboard. I had Nvidia 6200 Geforce graphic card earlier but removed it now and installed VGA drivers. When I restarted the computer it was very slow and in the task manager ''Image name...
Did you fully remove the Nvidia software? Sometimes you need to remove the software for the card because it is trying to load when windows starts and cannot find the card. You can also try and disable the agp or pci-express slot in the bios and see if that helps. Also make sure that the onboard video can run the directX version you have installed on your system. If the Nvidia card runs on directX 9 and the onboard video can only run directX 8 and directx 9 is running on your PC then that will definently cause an issue.
Sep 05, 2009 | Intel D101GGC Motherboard
Explorer.exe uses all available CPU
Norton anti-virus is a resource HOG. Disable it from running at start-up. It may be trying to download updates as the pc is booting. Use AVG anti virus, it is free and works very well.
Dec 28, 2008 | Microsoft Windows XP Professional
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Philips SPC 200NC Webcam
Midi Trouble with Reason
It is possible that your PC is too slow, but there may
(of course) be other causes
I have experienced a situation with Adobe Audition, causing
recording drop-outs when my PC got too busy.
To test this theory:
1) Shut down all unnecessary applications.
2) Go to the command prompt and disable the internet:
type: IPCONFIG /release.
to restart it later, reboot the machine or type:
IPCONFIG /renew
3) Go to the task manager and stop all unnecessary
processes:
press: control-alt-del at the same time and then
choose the "processes" tab
right click on each process you don't need
and stop the process
4) You should be able to reduce the number of processes
into the low 20's, but you need to keep the following:
a) Your midi application (Reason etc) of course
b) alg.exe
csrss.exe
explorer.exe
lsass.exe
svchost.exe (all of them)
services.exe
smss.exe
system
system idle process
winlogon.exe
5) Now go into the control panel --> administrative tools ->
services and stop all unneeded services
(the system will not let you stop anything essential)
6) Don't worry about stopping tasks and services,
they will all restart to normal when you reboot the
machine.
7) Go back into the task manager and right-click your
midi-application. Increase its priority to HIGH,
but NOT real time, because this may cause windows
to hang.
8) If your midi acquisition improves, then speed is the problem,
otherwise, look elsewhere:
a) re-install audio and midi drivers
b) make sure the mixer and control applets are correctly
configured, i.e make sure the midi is not muted.
e) make sure the midi application is allocated the
max amount of memory, if it has a setting for it.
etc.
9) I am assuming that you are running Windows XP.
If your PC is too slow do NOT use Vista !!!!,
which makes things much worse, at least
by a factor of 4 to 1
Do not install XP service pack 3 either,
its bloated with anti-piracy **** and DRM.
10) Finally, for audio work, I would recommend
a minimum system with:
a) Pentium III 800 MHz or better yet a Pentium IV
at 1.5 GHz or faster.
b) One Gbyte of RAM to make sure your machine is not
disk bound. This is much more important than a fast
CPU.
Disk is approx. 10 million times slower than RAM,
so this can become a very significant bottle neck.
c) Windows XP pro, SP2 (not 3)
d) Depending on your video card, i.e. the amount of
workload it handles for the CPU, you may also reduce
the screen resolution, and disable desktop effects
to speed thing up.
Adobe audition, for example will perform more reliably
on slower CPU's when the GUI window is kept small
in waveform or spectrum display during recording.
Good luck,
Martin
P.S. I use Adobe Audition for most of my recording and
audio processing. System = Core 2 Duo /2.4 Ghz,
4 Gigs of RAM (only 3 Gigs are accessible from 32 bit
windows XP), 1300 Mhz front side bus, 3.5 Terra Bytes
of hard disk, of which 1.5 Terabytes are configured as
RAID-5.
Speed and storage is no longer an issue :)
not even for HD video processing.
Jun 01, 2008 | Propellerhead Reason 3.0 (991010004) for...
Moniter activation when turning on the cpu
RESETTING DRIVERS with new Video CARD- Start the computer in SAFE MODE (Hold Shift F5 when restarting PC) Go to Control Panel> System>Hardware>Devices - Remove the Old Card Driver (under Video) Press OK (and then Exit) Put the Driver disk in PC - Restart Normally Option 1 When your system reboots it will be in 640x480 16 color mode ignore any prompts. Run Setup from the CD/drivers disk Reboot Windows restarts with corrected drivers Set the Screen Resolution to your choice typically 1024x768 Option 2 When your system reboots it will be in 640x480 16 color mode When your are prompted for the drivers BROWSE the CD/drivers disk- (usually \drivers folder) Select your card from the Mfg list Press OK, OK Reboot Windows restarts with corrected drivers Set the Screen Resolution to your choice typically 1024x768 **Note - there is no shortcut you have to reboot when prompted, especially in safemode. Good Luck Remember to let us know and rate the answers. otherwise theres not sense in answer questions, if you don't know if it helps anyone.
Oct 12, 2006 | E-Machines W4885 PC Desktop
Generic Memory nVIDIA FX5500 256MB 8x PCI Dual Head Video Card Graphic Card Logo
323 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
