Question about Vacuums
Rainbow e2 won't run on low speed runs poorly on high
It will run on high but not on low. I was use it yesterday on high for bout two hours, cleaning. I changed the water and had water level correct. I got done and switched it to low, it did nothing. Turned on high came on. I took,the HEPA filter out washed it, now it barely runs, the water just swirls slowly in the bowel
  • Vacuums Master
  • 1,460 Answers
Your model has a modulator that may be defective. Take it to a repair facility
Posted on Jan 29, 2014
4 Suggested Answers
SOURCE: My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Posted on Jul 19, 2008
C4RN1
  • 14 Answers
SOURCE: I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Posted on Jul 31, 2009
  • 8404 Answers
SOURCE: how do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Posted on Sep 23, 2009
Vacuum has power but wont run
From your question it sounds like the Rainbow will not run on high speed. Very good chance the Controller Asm 120v e2 Silver Gold is bad. Call us when you are able as we can replace at a discounted price if your machine meets the requirements. Contact Us
RainVac
Sep 07, 2015 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow E2 will run on High speed,but not the low speed.it's as if no power is getting to it,when.you try to switch it on low,but works fine on high
This could be one of two problems. It could be your switch is broken, preventing it from going to low speed. Try clicking it, does it still make a distinctive click sound, does it feel loose? If so it may be your switch: Rainbow e2 power switch
Otherwise if may be your computer in your E2 is starting to go bad. Often times if Rainbow stops going into one of the speeds it is due to a computer going bad. This is an expensive part and repair, so you should probably take it in and make sure it is the computer. Rainbow E2 controller 120v
800-775-6586
GoodVac com
Feb 13, 2015 | Rainbow Vacuums
The e series rainbow 2 speed works only on low speed. High speed will not run. What is srong?
It is either the switch or the controller. Call us and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
800-523-0510
Jul 23, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacum works on low but not on high??????
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other hacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jun 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
No power
You must have a late model 2006 or newer E2 two speed Rainbow vacuum that has the white foam padding in the canister, to dampen the sound of the motor, and has a red light on the computer board.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other vacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
Thank you,
Ralph
Feb 20, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
