Reset instructions after replacing the paper and batteries, will not power at all.
Paper is becoming continually jammed
If the paper path is cleared and still blinking, try unplugging the cartridge while on and replace it. Reclose the printer door a couple of times. Sometimes it will catch and not reset.
Nov 20, 2012 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Sep 09, 2011 | Woods Industries 59377 Indoor Digital...
My 24 digital timer its not working! isnt there anyway to reset? it doesnt show anything on the screen!! why?
If plug-in timer does not display, then
1) Reset button has tripped > push reset with paper clip
2) power is off > plug something else in receptacle to check receptacle
3) timer is loose in receptacle > unplug timer, spread prongs a bit, and plug back in
4) timer has gone bad.
Except for a few Woods and Intermatic outdoor timers, plug-in timers have internal rechargeable battery. Battery is not replaceable so when battery goes bad, the timer is bad.
See other Woods plug-in timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
59203 plug-in timer at Amazon for $12
http://www.amazon.com/Woods-59203-Digital-Appliance-Repeats/dp/B001Q9EFU0
If you buy a timer, save the instructions like gold so you don't have to write fixya next year looking for instruction that nobody can find.
Nov 19, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
The battery on my Casio Waveceptor watch - model 4723 - has just been replaced, but the jeweller did not know how to reset it to the correct time. I have downloaded the user operations guide, but the watch...
Your watch probably needs a reset after the battery change.
Take the back off the watch. Examine the movement carefully - you should find a small electrical contact point marked 'AC' (which could be quite small). To perform a reset you will need to temporarily connect 'AC' to the '+' terminal of the battery (basically, the upper side of the battery). If you have some fine point tweezers they are ideal, but a bent paper clip (not a plastic coated one) will do.
Be very careful not the make metal contact with any other part of the movement!
Place one end of the paper clip on the 'AC' contact and, for 3 seconds, place the other end on the battery '+'. As watches sometimes need to be reset twice, there's no harm in repeating the operation while you have the back off the watch.
Once successfully reset, you should have no problem with setup and the watch should behave normally.
Hope this helps.
Aug 29, 2017 | Casio Watches
Paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Mar 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
DISK WON'T LOAD, TURN ON AND ALL THE LIGHTS CONSTANTLY BLINK
Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00095617).
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
  4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
  1. Make sure that the computer and the HP All-in-One both have a three-prong power plug.
  2. Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
  1. Unplug the power cord from the unit.
  2. Reconnect the power cord into the unit.
  3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
  4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
  5. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
  1. With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
  2. Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
  3. Reinstall the print cartridges.
    • The black or photo cartridge goes on the right.
    • The tri-color cartridge goes on the left.
  4. Close the cartridge access door, plug the printer back in and turn it on.
Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Camera will not switch on
my camera will not show power when plugged into the dock, I had power from this before. Is it the dock or my camera that isn't working properly? Thanks Joanie October 2,2008
Feb 25, 2008 | HP Photosmart R717 Digital Camera
Forgot password
Have you performed HardReset If you havent you may watch the instructions
Feb 20, 2008 | Palm Tungsten E2 Handheld
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
